It's a destroyer, and I haven't been able to find much about how the turrets were actually used, aside from some accounts on the Normandy landings. |
U.S. Destroyers had 5" mounts. These are utility rifles, and can be used for surface to surface, shore bombardment, or AAW, depending on the round used. Unless in actual use, the fore mounts faced forward, the after mounts, aft. If all mounts were being used for shore bombardment, they would all be facing the same direction, elevation depending on distance to target. If used in AAW, each mount could face a different direction, and elevation. Multiple surface to surface targets would require each mount to face a different direction, and possibly different elevation. As I recall, twin mounts, unlike turrets, cannot separately elevate their barrels.
"call for fire, ten rounds, main armament, fire for effect, over"......."shot, standby, out"
