hi im wanting to build a uss texas the way she looked when comm. in 1914 w/ the cage masts.i cant seem to find any models w/ cage masts already built, so i am going to make them.any ideas on how i should go about doing this? thank you in advance..
Firstly, the cage mast consists of 48 absolutely straight tube (I use brass wire to represent those tubes). As other comments have afirmmed, 24 lean ledt and the other 24 lean right. Thus, a circle of 48 holes the diameter of the brass wire used forms the base. I use a central pivit under my drill press to insure the holes are on the same radius. A given tube (again, using wire) leans aboit 30 degrees to the upper platform and 90 degrees further around the circle. The next wire leans in the other direction to the upper 90 degree point. I support intermediate platforms such as searchlight mountings with a pair of dowels OUTSIDE the cage structure. A central dowel would get in the way of the 'chain link" decks that cross the interior of the mast (3 in the case of the TEXAS).
The upper "crows nest" at the top of the TEXAS cages is a simple bucket with an uphostlerd bench 270 degrees in diamete inside . A floor hatch that is inside the bucket occupies the 'missing' 90 degress of the bench. Ladders run between the chain link decks inside the cage to this hatch.
At each lower intersection of the wires an inner and outter wire smaller in diameter than the vertical wires encircle the cage. An even smaller wire (I use delaminated strands from stranded wire for this) forms the clamp that holds the mast togather.. An extreamely light touch of solder seals the 'clamp' at each intersection. Higher up the mast some intersections do not have the inner and outter rings. Floating Drydock had plans of ths New Yory, which was TEXAS's sister ship. Use those for details.
I built TEXAS in 1/96th scale, so my job was easier. She sank on the second voyage due to water entering the casement gun ports.
