Arizona ships boats. Were they onboard Dec 7th?
    December 2003
Posted by hkshooter on Friday, July 14, 2006 9:08 PM
I'd like to build it as it looked that day.
    October 2005
Posted by usmc1371 on Saturday, July 15, 2006 12:01 AM
Interesting question.  The answer is probably not.  Here's why:  The battleships were moored in port and the ship's boats would be needed to ferry the men to shore and back.  It was Sunday, so a large portion of the crew was ashore for liberty.  Also, photos just before the attack show other ships like the Nevada with the ship's boats moored along side.
In this picture, the Nevada is in the lower left.  You can see the Nevada's boats next to in the water:
In this picture, you'll notice there are no boats on the port side of the Arizona (can't see the starboard side):
Lastly, if you want to do an accurate model of the Arizona during the attack, you'll need to add canvas 'tent' covers over the bow, stern and midships.  This was common to do when in port.  If you look in the following picture you can see the 'tent' covers on the battleships at these locations.  The 'tent' covers have a bright reflection:
In the second picture, you can see the 'tent' cover over the stern catapault.  In the first picture, you can really see the covers on the Arizona (second ship, inboard, lower left).
Hope this helps,
Jesse
    October 2005
Posted by usmc1371 on Saturday, July 15, 2006 7:35 AM
Further note:  In Paul Stillwell's book "Battleship Arizona", on page 234, he writes "Members of the crew went over the side and swam to the Arizona's boats that were tied up to quays and booms."  I think that pretty much answers it.
Also, in regards to Arizona's configuration on Dec. 7, besides the canvas 'tents', there are three other items to note:
1.  On top of the foretop is a pedestal for an air-search-radar antenna that was to be installed.  If you are using the Banner kit, it's missing.  See this pic:
2.  On the main deck level, there are two tubs (one port side, the other starboard) for 1.10"/75 antiaircraft quad machine guns.  These guns were not installed as of Dec. 7, therefore the tubs were empty.  The guns are included in the Banner kit.
3.  The boat booms would of been extended with the boats being in the water.  The Banner kit's instructions show the retracted.
If you have any other questions, please let me know.
Jesse
    December 2003
Posted by hkshooter on Saturday, July 15, 2006 8:21 PM
Great info. Thanks!
I'm already leaving off the planes, the range clocks and the guns for the tubs you mentioned. That much I've figured out. Someone asked me the other day if the ships boats were onboard or not and I must have got the most dumbfounded look on my face. I had no idea! But your logic makes sense and the Stillwell comments confirm what you say. I really need to buy that book.
I havent decided yet if I want to add the canvas sun shelters or not. I'm not building a dio or anything like that. And the covers would hide some of the detail like the PE stern catapult and the anchor chains. Decisions, decisions.
BTW, I am using the Banner/Minihobbies/ whoever else kit. Both the GMM and Tom's PE plus Tom's PE for the ships boats. Which I may now not need.Wink [;)]
Edit to add a question.
You mentioned that the AA guns were not yet installed in the new gun tubs but you only mentioned two. There are four of those tubs in the kit and supplied in the GMM PE also. Were there going to be four of those guns or just two?
    October 2005
Posted by usmc1371 on Sunday, July 16, 2006 10:15 AM
No problem.  I had never realized that the range clocks had been removed.
I forgot about the other two AA guns on the deck level, forward.  They weren't installed either but the tubs were.
I diffently recommend getting Stillwell's book.  It's a great read and has a boatload (pun intended) of information.
Did you get the motorized Banner model or the static one?  The hull near the screws are different between the two.  The motorized one has an battery compartment in the lower hull, center.
Check out this guys build; it's amazing:
http://www.rollmodels.net/nworkbench/onlinebuild/arizona/arizona1.php
Jesse
    December 2003
Posted by hkshooter on Sunday, July 16, 2006 4:19 PM
Jesse,
I got the motorized/changed back to static kit. Comes with the steel prop shafts and the square battery box.
The build you listed is the same one I've been using for motivation and reference for my own build. The guy really knows his stuff! His work is amazing. And I primarily used his example to correct the hull where the battery powered shafts came thru. Made my won running gear and all.
GMM says that Both of Arizona's range clocks were removed by February of 41. And I've been wondering just what they were for and how they were used. I was in the Navy myself but have never figured it out.
    October 2005
Posted by usmc1371 on Sunday, July 16, 2006 5:10 PM
I got the range clocks on mine but now I realize I'm wrong.  Oh well.
The clocks have numbers on the dial from 0 to 9, clockwise. It has two hands, a long one and a short one.  The two hands indicate thousands and hundreds of yards so that individuals on board other ships can observe with binoculars the range that the guns on the Arizona are firing.
Nothing like a Marine schooling a Sailor on how a ship works Wink [;)].  Just playing with you.
Jesse
    December 2003
Posted by hkshooter on Sunday, July 16, 2006 5:29 PM
Eh, who cares. I thought about putting them on just because they looked cool but decided against it.
ROTF!!! For sure! Don't tell your corp buddies or you'll never live it down. How dare you help out a squid!Shock [:O]Laugh [(-D]
    October 2005
Posted by usmc1371 on Sunday, July 16, 2006 6:12 PM
So when were in the Navy?  I was in the Corps from '91 until '99.  I spent time on the USS Tarawa, Fort McHenry, Cleveland, Tripoli, and Rushmore.
Jesse
    December 2003
Posted by hkshooter on Sunday, July 16, 2006 6:57 PM
I was in 87-91. On a tin can called the USS Dahlgren, DDG43. Did EastPac. In hindsight I should have joined the Marines.
Posted by rcboater on Sunday, July 16, 2006 8:48 PM
Do you still have the propshafts?  Did they include working props?  (I'm always on the lookout for small diameter props sutiable for use in converting plastic models to Radio Control operation.)
Webmaster, Marine Modelers Club of New England
www.marinemodelers.org
    April 2005
Posted by ddp59 on Sunday, July 16, 2006 8:56 PM
    December 2003
Posted by hkshooter on Sunday, July 16, 2006 10:04 PM
I still have the shafts. They are just .080 steel rods, 4.750 inchs long. No props as the kit only came with the 350 scale styrene props. Not very nice ones at that. If I had been able to find resin ones I'd have used them.
    June 2003
Posted by Steve H. on Friday, October 27, 2006 11:39 PM
Hi
In the book "Battleship Arizona. An Illistrated History" by Paul Stillwell. On page 234 there is a painting of the Arizona with the repairship Vestal outboard of her just before the attack began. It shows some of her ships boats on the boat deck, and 2 off her stern inboard side mouring "booms". This is the way I will model my 1/700 scale Arizona in diorama.
Steve H
    April 2006
Posted by waynec on Saturday, December 23, 2006 9:51 PM
bit late responding. there were 4 gun tubs for 1.1" quad aa guns. 2 forward on either side of the bridge on the anti-aircraft deck. they has 5"/51 surface guns earlier but these were removed for the 1.1". there were 2 tubs on the quarterdeck just forward of no. 3 barbette. again no 1.1" were mounted. no a/c were aboard on. in tom freeman's dawn of destiny the gigs are alongside.can't tell about the rest of the boats. hope this helps.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
