Modern DDG FS Colors
    August 2006
Posted by ScottU on Wednesday, August 9, 2006 6:46 PM
I have a Dragon models 1/700 scale DDG-89 model that references the incorrect FS colors (I think). The pictures I have seen of modern destroyers have a very dark deck compared to the gray color called out on the instruction sheet. The sheet calls out FS36440 for the sides of the ship and FS36320 for the deck. Any help would be greatly appreciated.
    August 2005
Posted by EdGrune on Thursday, August 10, 2006 10:24 AM
Modern US Navy Haze Garay is 26270.  Modelmaster Neutral Gray is 36270 - so you're good to go there.  Overcoat with satin vs flat -- but my personal peference is to stay with the flat as my bow to scale effect.
I don't happen to have the spec for deck gray handy, but MM Gunship Gray is a good match.
New, unweathered flight deck antiskid is done well by MM Engine Gray.  It weathers toward the Gunship.   You might paint the deck & apply the deck marking decals - then apply a LIGHT dusting of Gunship to tie it all together.
    August 2006
Posted by ScottU on Thursday, August 10, 2006 1:54 PM
Thank you very much. You answered my next question about scale effect before I could ask it.
    August 2006
Posted by ScottU on Thursday, August 10, 2006 3:57 PM
Ed,
Could you tell me how you think this water was made?
    August 2005
Posted by EdGrune on Thursday, August 10, 2006 5:52 PM
The water looks to be made from a textured plexiglas of the type used for recessed light fixtures or for shower doors.   Paint the reverse and use white artist's tube paint & gloss medium to attach the ship so that it isn't just sitting on top of the wave bumps.
Posted by navypitsnipe on Thursday, August 10, 2006 9:04 PM
well seeing as how Deck gray is the most commonly used color of paint in my division, i will attest to Gunship gray being a good (nearly perfect) match. instead of neutral gray i use a 40/60 mix of dark gull gray/light gull gray which is slightly lighter in color (than the actual FS match) and hence gives a more accurate representation for the scale.
40,000 Tons of Diplomacy + 2,200 Marines = Toughest fighting team in the world Sis pacis instruo pro bellum
    November 2003
Posted by Mike F6F on Friday, August 11, 2006 7:38 PM
I too am working on a 1/700th scale Burke-class destroyer. Im building the Skywave kit.
I've used gunship gray for my deck surfaces, but your choice depends on how you wish to represent the ship. The nonskid and painted surfaces fade very quickly in sunlight. If you want your ship to look straight from the drydock, go with any of the choices mentioned above.
If you are choosing to show your ship with some weathering, check some photos at the Navy Newsstand website: www.news.navy.mil. You'll see much lighter shades of gray on the decks.
I use a mixture, or do a dry brushing, with pale gray to "fade" the deck somewhat.
Its all in the "look"you want your model to have.
Enjoy.
"Grumman on a Navy Airplane is like Sterling on Silver."
    August 2006
Posted by ScottU on Monday, August 14, 2006 3:04 PM
Thanks Mike and all for the wealth of information. This forum is such a great resource for modelers.
