MinyHobbyModels USS Arizona
    September 2006
Posted by Ensign19 on Tuesday, September 12, 2006 7:10 PM
First time posting here, but I've been enjoying FSM magazine for a while now.
My problem:
I recently purchased to MinyHobbyModels 1/350 scale USS Arizona from Hobby Lobby. Upon beginning construction of the kit, I found that it included no doors, life rafts, railings, etc. etc. It also had "aztec temple" molded-in stairs. The edges were parts fit together were actually bevelled, creating horrid gaps, and it included no paint chart. My question is, has anyone purchased this kit? If so, how can it be turned into a reasonably good model (besides a liberal use of gap-fillers)? Please help! Thanks
    March 2006
Posted by Dubau on Tuesday, September 12, 2006 8:55 PM
1st off Sign - Welcome [#welcome] to the Fourms.
And I am sorry to say I don't know about the model of the Arizona you have, I never build one, BUT I know you will get a lot of help here form others.
Have a GREAT day and have fun
Bud
" You've experienced a set back, and without set backs and learning how to fix them you'll never make the leap from kit builder to modeler "
    August 2005
Posted by EdGrune on Tuesday, September 12, 2006 9:57 PM
The MHM USS Arizona was originally released by Banner in 2001.   Banner, Trumpeter, and MHM are all part of the Wasan Moulding Co. of China.   They share molds among themselves.  MHM has a reputation of pirating or cloning others original work.   MHM's details are often soft.  What you have is an example of Wasan's first attempts at a 1:350 scale ship model.  The model itself is a pantograph/re-engineer of the old Revell 1:426 scale kit.   They made some 'improvements' to the kit -- notably they removed Revell's molded-on railings that were often mistaken for brick walls.   They also introduced some problems of their own.
There is fit issues with this kit.   You will have to address them with putty and/or shims of plastic.
You will want to shave off the aztec temple stairs.   Improvement to the kit include photoetch from White Ensign,  Gold Medal Models, or Tom's Modelworks.   Tom's sells replacement/ehnacement resin sets that improve some of the deck fittings.   LionRoar makes PE applique bulkhead details.  Stilwell's "Battleship Arizona" published by the US Naval Institute Press is the recognized authoritative reference on the ship.
Paint - the simple answer is, on December 7th, the Arizona was wearing Measure 1.   The painting instructions for this call for Light Gray on the masts above the funnel tops.  The hull and superstructure below the funnel tops were in Dark Gray (so dark it is almost black).   The steel decks were in the same Dark Gray.  The wooden decks were polished bright teak.   There has been some controevrsy as to whether the Arizona and others in the Pacific Battlefleet were in Measure 1 of Navy Blue.   The sum evidence has not been subjected to extensive peer review - and until then the standard color assigned is Dark Gray.
Out of the box, build it and enjoy it.   Don't worry about the missing or soft details.
If you seek to improve on the kit, be aware that it will take some time and effort to correct some of the shortfalls of this kit.
    December 2003
Posted by scottrc on Wednesday, September 13, 2006 7:11 AM
The biggest problem I had with this kit was the seam at the gun deck / main deck joint.   I ended up using stretched sprue (see October issue of FSM) and spot glaze to fill it and re-drilled the port holes.
    September 2006
Posted by Ensign19 on Wednesday, September 13, 2006 1:50 PM
Right, thanks all for the help and warm welcome. Greatly appreciated.
Posted by Anonymous on Wednesday, September 13, 2006 2:00 PM
Mike Ashley did a wonderful article on building the 1/350 Arizona(Banner) a few years ago. Should be available via back order purchase. Search under 1/350 Arizona. He also did a Pennsylvania conversion. There is a multipage buildup at www.rollmodels.com here is link  http://www.rollmodels.net/nworkbench/onlinebuild/arizona/arizona1.php
There are probably a bunch others on the net and Ed Grune. knows his stuff as well.
Oh, what color were you thinking of painting the model?
    April 2005
Posted by ddp59 on Wednesday, September 13, 2006 4:22 PM
    June 2005
Posted by smokinguns3 on Wednesday, September 13, 2006 4:32 PM
Ive got the banner kit havent built much of it but i bought the toms modelworks pe set and all i can say is stay away from it there instructions suck like a hoover vacume if i did it again id go WEM GMM thats just my My 2 cents [2c]
Rob I think i can I think i can
    September 2006
Posted by Ensign19 on Thursday, September 14, 2006 2:08 PM
Thanks for the further links and help.
Measure 1, as mentioned in a above post by another member (although I had gotten the light grey mast color confused with white)
Posted by Anonymous on Thursday, September 14, 2006 2:39 PM
Ok. Just checking in case of Sea Blue.
