Hi,
Some progess pictures are below.
1. I drilled lightening holes in the plate supports on boat's stern.
2. Made thinner sides of air intakes.
3. Drilled the exhausts, cut out platforms for smoke generators (they will be replaced), tried to decrease V of the hull (slightly sanded it off, no surgery), moved positioning hole of the center rudder up (to line up all the ruddres).
4. Added some details on the gun tubs.
5. Sanded off the torpedo loading cradles and restored the deck (I will install my cradles after the deck is glued to the hull), sanded off central sections of DC racks and added some details on them, drilled air intakes holes to add some depth, rebuilt the hatch (replaced the inclined cover with a horizontal one).
