jepot wrote: |
thanks for the quick reply sir!!! man, a resin and PE kit...oh boy...a tough job ( not to mention a COSTLY kit) to build...thanks again sir! |
Not as costly as you think. Let me run some numbers past you as an example. They are based on kit MSRP and todays exchange rates. Your milage may vary:
PitRoad Vehicles on Beachead (for LCVPs) 600 Y => $5.10 USD
PitRoad Buckley DE 1600 Y => $13.60 USD
Toms Modelworks DD PE $ 8.00 USD
or
Gold Medal Cruiser/DD PE $ 20.00 USD
Styrene stock (sheet & rod) $10.00 USD (estimate)
Total $36.70 to $48.70 (plus research material & time)
Versus
NIKO DE APD 34.95 Euros => $44.95 USD (complete, structures & PE)
So, you can see that if you start with the basic kits and build your own APD, your cost is in the same order of magnitude as if you go out and buy the complete kit from Niko. Oh, and you still have to scratchbuild the boat handling mast from styrene stock if you go the piece part route.
