- Member since
August 2006
Thanks, those will definately help when creating aves and wakes around my LCM and other bits of debris and barricades on the shores of Omaha. I have been using some of that white caulking goo on test bits of resin "water" as waves, and it looks decent I guess. Also those fake snow products by woodland scenics, when I us tiny bits of it sprinkled over the waves it makes realistic foam and air bubbles in the water, looking like white caps and splashes. More importantly, Im trying to find out how to do realistic bullet splashes, and their underwater trajectory and mortars hiting the water/depth charge kind of effect. So far, my best method for the underwater trajectory is painting a piece of wire silver/whit/grey and smear on tiny amouns of caulking goo and sprinkle on fake snow. I stick this in my resin water as it dries. When its almost dry, I pull out the wire, and it leaves some of the stuff it was coated in, along with a "hole" in the water and as it is pulled out, air bubbles form in the resin, it looks pretty good. For the above water splashes, I have been using caulking goo, 5 minute epoxy, fake snow and mostly cotton/stuffing in small tufts. finally I spray it in gloss for a wet effect. For mortar explosion, I just made a mold out of tin foil and poured in resin, then I will cover it in all kinds of stuff, fglosses, cauliking, the fake snow, whatever I can to try and make it look good. Ill post pictures later today.
"Scanlon: work your knobby hands on the table in front of you, constructing a make-beleive bomb to blow up a make-beleive world."
