Problem with Modelmaster paints
    August 2006
Posted by Robert on Sunday, October 29, 2006 2:06 AM
What am I doing wrong? Every time I use this brand, when I put the second coat on the first starts to come off. I have just put a second coat on a deck piece after waiting three weeks for the first coat to settle and it still happens. I wash the plastic first, use a clean brush, all the things you are supposed to do, and I wind up with an impossible mess and have to get out the oven cleaner. This problem never happens with Humbrol.
    July 2013
Posted by DURR on Sunday, October 29, 2006 11:51 AM
wait over 4 weeks or wait 20-30 min  nothing in between
    February 2006
Posted by Wilbur Wright on Sunday, October 29, 2006 5:46 PM
  ARE you speaking of MM enamels?  I have been using them for at least 15 years and never a problem like you describe.  Make sure the paint is fresh, not old.  I recently paintedd the deck of my CSS Alabama with MM Sand, and had no problem with 2 coats by brush.
You've got to use artist quality red sable brushes, I get mine at Pearl Paint ( a real art store), they are expensive yet last so its money well spent, and gets the job done right.
    December 2003
Posted by scottrc on Monday, October 30, 2006 7:38 AM
You may have a combination of old paint, too thick a base coat, and the surface may still have release agents on it.
Are these Acrylics or Enamels?  Are you painting a flat over a gloss?  Has your paint ever been subjected to extreme cold?  How old is the paint?   Is there any cleaning or dusting sprays being used in the house close to the time you painted for these carry sillicates that will deposit on your surface to paint and will cause fisheyes and peeling.
Do you paint where there is high humidity?   Are you painting a light base coat or a heavy base coat?
My experience with MM has been hit and miss depending where I buy it.  Sometimes I get old paint, and sometime I get paint that was frozen in shipement which could lead to cure problems.  All paint brands are subject to this problem, its just MM is more readily available hence why I see more problems with this brand.
Flats won't adhere to gloss nor Acrylics to Enamels.   Acrylics may need a good primer coat prior for a good adhesion.   Also, try wiping your surface with a cloth dampend in automotive grade laquer thinner before putting on your first coat.  There may have been some release agents that couldn't be removed with detergent.  I would suggest priming the surface and use very light base coats.
Scott
    January 2003
Posted by cthulhu77 on Monday, October 30, 2006 7:49 AM
  Until I fell in love with the Tamiya no-drip jar, I had always used MM acrylics and enamels, with no problems at all.  I agree with Scottrc, it sounds atmospheric.
                      Greg
http://www.ewaldbros.com
    March 2004
Posted by subfixer on Monday, October 30, 2006 9:27 AM
One thing I learned about the Moel Master acrylics; do not shake the bottle to stir it up. You must stir it with a stirring stick. If you do not, the paint will harden up in the bottle due to the aeration and no amount of thinner will make it recover. Tamiya acrylics are not affected in this way for some reason (maybe because they have an alcohol based thinner). I don't know about other brands except for Humbrol. I have a few little tins of Humbrol (enamels) that are still viable at over thirty years of storage. I must admit that I haven't really used them much over all this time, but they are still in liquid form in there. Amazing!
I'm from the government and I'm here to help.
    March 2005
Posted by mfsob on Monday, October 30, 2006 10:47 AM
Atmospherics, or age, as has been suggested. I run into that at my local hobby shop all the time - she has the full assortment of Model Master enamels, including marine and automotive, but as to how long some of those shades have been sitting on the shelf ... I dunno, maybe dinosaurs were still roaming the earth?
There have been two instances where I bought a bottle, took it home and found out it was doing an excellent imitation of The Blob. Took those back and got a prompt refund or exchange, but a word to the wise - If it has an inch of dust on the lid, is rusted to the racks,  the lettering on the bottle appears to be Aramaic or it resembles something you'd normally see in the lowest, darkest corner of your refrigerator, just leave it be.
    January 2003
Posted by cthulhu77 on Monday, October 30, 2006 6:36 PM
"the lettering on the bottle appears to be Aramaic "
      ROFLMAO...
    "Indy, Indy!  That paint is cursed!"
    February 2006
Posted by Wilbur Wright on Monday, October 30, 2006 9:06 PM
They should date the paint on the jar. If you have a busy LHS as I do... I know the paint always moves, at  least the blacks and whites and other frequently used colors.
    October 2005
Posted by usmc1371 on Monday, October 30, 2006 9:32 PM
Testors states that their Model Master paints have a shelf-life of 3-5 years.
-Jesse
    March 2004
Posted by subfixer on Tuesday, October 31, 2006 9:34 AM
Getting back to what I was saying about shaking Model Master's Acrylics.. An employee at my LHS told me to buy the paints from back of the display rack because customers will take the front line bottles and shake them and then put them back in the rack. This, he said, will cause the paint to blob up. He was the one who advised me to stir this brand of paint rather than to shake it. My paints have lasted longer since I have been treating them in this manner. 'Nuff said.
    August 2006
Posted by Robert on Wednesday, November 1, 2006 3:33 AM
Thanks very much to all for such helpful advice and tips. I am planning to use MM sand for the deck of my new Kearsarge and when I figure out how to post photos (which may take quite a while) hopefully you will see a good result.
    January 2003
Posted by cthulhu77 on Wednesday, November 1, 2006 8:52 AM
  Do a search here on replicating wooden decking...lots of good information! Looking forward to seeing your progress.
          Greg
