Glue Sniffing?
Glue Sniffing?
Posted by Anonymous on Wednesday, September 3, 2003 5:14 AM
Lately the fumes from the glue I use for most work (Zap A Gap) is causing me some lung problems. I am going to suspend work on models for a while and see if it clears up.
Anyone else have this problem?
Ques
Posted by Anonymous on Wednesday, September 3, 2003 10:16 AM
Sorry to hear of your misfortune, Ques. I have not had this problem, although at certain times, CA glue can irritate the eyes a bit. Have you been using adequate ventilation while working?
demono69
    January 2003
Posted by Jeff Herne on Wednesday, September 3, 2003 11:44 AM
Cyano can be nasty on the lungs in confined spaces without adequate ventilation, especially if you have a pre-existing condition. My wife has asthma, albeit mild, and she can't be in the same room .
ZAP also makes an oderless CA which I've never used. That could be an option.
Jeff Herne
Modelwarships.com
Posted by Wolfp on Wednesday, September 3, 2003 10:47 PM
Only time I have had a problem is when leaning in just a leetle too close, and rather than exhale inbound, I inhale. I quickly find myself moving away from the source of the problem, but I cant say it has ever caused respiratory distress.
J.B. http://photobucket.com/albums/a303/jbrunyon/
On the Bench: !/350 TOS Enterprise; 1/72 Tie Interceptor
Posted by Anonymous on Thursday, September 4, 2003 11:49 PM
I've found that CA gives me some pretty nasty 'allergy' symptoms. Just like getting a bad cold. Usually isn't a problem with adequate ventilation and if I use it sparingly. I also found that using accellerator made the whole problem worse.
Now I use liquid Ambroid Pro-Weld (or something similar) as much as possible. I still use CA, but nowhere near as much as I used to. It's a good thing, because I prefer the Ambroid now that I've used it more.
I also find that I'm using epoxy more than I used to.
Murray
    May 2003
Posted by styrene on Friday, September 5, 2003 10:06 AM
Both the ethyl and methyl forms of the cyanoacrylates have the ability to cause sensitization reactions in susceptible individuals. Skin sensitization can cause dermatitis, while inhalation sensitization can cause asthma-like symptoms. The concern with inhalation sensitization is that repeated exposures to even minute amounts can trigger an asthmatic, or asthma-like response. The best way to avoid repeated exposures is to get rid of your cyanoacrylate adhesives and find a suitable substitute--even adequate ventilation may not reduce the vapor concentrations low enough to stop a reaction from occurring. It would be advisable to see a physician who can correctly diagnose an allergy to this material, and treat it as necessary, if it remains of significant concern to you.
Gip Winecoff
