SK-2 Radar PE - AARRGH!
    April 2005
Posted by cruichin on Friday, November 10, 2006 10:26 PM
I finally got the nerve to assemble the YM PE SK-2 radar for my Trump 1/350th USS North Carolina. I followed the instructions to assemble the support braces first and then put on the rings. Yuck, lousy fit and look.
Into the acetone bath it went and I tried again, this time with a different approach. I assembled the two main braces and put the rings on working from the outermost in. After getting them reasonably set, I added the remaining braces to the back of the assembly. Got a much better fit and look, but still pretty amateurish.
So I still have a lot to learn! I spent three nights getting this done!
    July 2005
Posted by warhorse3 on Saturday, November 11, 2006 11:39 AM
I finally finished my North Carolina last month using 2 GMM sets and a L Arsenal Mk51 director set plus alot of scrathbuilding. Fifteen months and I figure almost 1700 parts later Im happy with it. I took it over to my LHS for the guys there to see the results and was asked by the owner if I would let it be put on display there. If I can ever take some decent pics of it I'll submit them to Reader Gallery. As far as the frustration level goes, I empathize. Try reworking all the 20MM gus using .006 wire for the barrels like I did. Savor the satisfaction when you get it done. It was worth all the trouble for me. Hope to see it here soon.
Regards, Bill
    March 2005
Posted by mfsob on Saturday, November 11, 2006 12:10 PM
Welcome to Hell, cruichin ... I mean, to the wonderful world of photoetch radar screens. My personal bugaboo is the SPS-49 found on modern US Navy ships, with the nastly little curve of the main screen and the tricky bending and gluing of the back brace. And then the bazillion times I manage to knock it apart while doing something else ...
That said, I think PE radar antennas are one of the things that really sets a model apart, and makes it look more like a miniature version of the real thing as opposed to a pool toy.
And yes, acetone is one of my best friends now as well!
Posted by Anonymous on Saturday, November 11, 2006 3:32 PM
Here is what I did in assembling my SK-2 on the Mo.
I assembled the cross braces directly on the outer ring, without removing the outer ring from the brass frett. I removed all the inner rings except the outermost. I then but the cross braces into place in the sequence as directed by the instructions. and lastly when all the cross pieces are in place I glued them to the outer ring. In this way the outer ring while attached to the brass fret acts as a template. It really is easy this way. Next after attaching the rmainder of the rings, I removed the assempled SK-2 off the fret.
I hope this helps
    April 2005
Posted by cruichin on Sunday, November 12, 2006 8:40 PM
Makes sense, holding the whole assembly still was the a pain in the rear. Next time, I'll do it your way.
Thanks!
