Hull Window
Hull Window
Posted by Anonymous on Tuesday, November 14, 2006 7:36 PM
New to ship modelling so I am sorry if I am not using the correct wording.   On the Trumpeter Hood on the hull there are port windows?...do you guys drill these out with a pin vice drill or leave them solid?
    August 2005
Port Holes or Air Ports
Posted by EdGrune on Tuesday, November 14, 2006 8:17 PM
They are most often called port holes or air ports.   The terminology varies with which side of the pond you are located.    Also on some pre-war ships that underwent wartime refits the port holes were plated over.   Chck your references for the exact configuration for the time period you are modeling.
If they are molded/cast uniformly I usually paint everything the camouflage colors, then go back with a 0.005 inch fine point pen (technical rapidiograph pen or equivalent) and fill them in.   Just touch the pen in the depression and give it a twirl.   I will also blacken in square bridge windows in the same manner.
If you are going to drill ports where there are none or they have been filled you need to take special care to make the spacing uniform and make them parallel (most likely to the waterline).  Also make sure that the hole sizes are uniform and are not skewed with the surface.
    March 2005
Posted by mfsob on Tuesday, November 14, 2006 8:20 PM
Welcome to the dark side, mate! You're close on what they're called - portholes.
As to whether you drill them out, it's personal preference. The Trumpeter Hood is 1/350 scale, so I'm not sure what size drill you'd use to open them up. I know in the 1/700 scale I use, a No. 75 is about right. It's OK to leave them closed, though, because that is how they'd be if the ship was buttoned up before combat.
