Building Board
    August 2005
Building Board
Posted by EdGrune on Thursday, November 16, 2006 6:41 PM
In a responce to cruichin, I mentioned that he should consider using a building board to minimimze handling the model and to aid in positioning the model to work on it.   The building board can be used to hold the parts for painting and to give you a level horizontal plane to work from.   Some stick & string ship modelers use something similar to hold their work in progress.
I make my building boards out of pine boards.  This one for a 1:350 scale USCGC Hamilton is made from 1x4 and is about 6 inches longer than the ship.  Size yours appropriately.
I put some block legs on the bottom to raise it off the surface.  They were glued and nailed with some finish nails.
I drilled some holes to match up with the mounting hardware previously installed in the hull and ran some bolts up through the bottom of the board ...
... and through some tube standoffs into the bottom of the hull
I attached an end piece to one end (1x4 and about 6 inches long - size yours appropriately)
It is attached with some screws so that I can swap ends with it if I need to get close to one of the ends.
In use, the building board can hold the ship upright (first picture), or laid on its side using the upright to keep the ship & board from falling over
You can stand the ship on its end  using the upright on the end as a base.   Clamp the upright to your table for added security.
And the board can be rotated on the upright to help you access hard to reach areas.
Hope these pictures give you some ideas on a building board fixture
    September 2006
Posted by reklein on Thursday, November 16, 2006 6:46 PM
Great Idea!!! Thanks ED
Posted by rcboater on Saturday, November 18, 2006 11:36 AM
A 1/350 scale Hamilton-class WHEC, post FRAM?   What kit is that?
Webmaster, Marine Modelers Club of New England
www.marinemodelers.org
    August 2005
Posted by EdGrune on Saturday, November 18, 2006 12:07 PM
That is the Iron Shipwright kit, resin & brass.   Quite nice, can be made as either pre- or post-FRAM.  It comes with almost a full set of decals for the whole class, racing stripe and all.   I just need to contact Darren Scannell of Hawk Graphics,ISWs decal designer, for a set of bridge-wing salad bars and marijuana drug bust leaves.   There are full decals for both the RHIB and motor life boat, stripes and all.  Also has a Dauphin or Pelican (?) embarked helos (PE rotors).
Posted by Jim Barton on Saturday, November 25, 2006 9:38 PM
What a shame my father's no longer with us. He built wood sailing ship models and he would've loved that building board!
"Whaddya mean 'Who's flying the plane?!' Nobody's flying the plane!"
