Resin deck hardware and tecniques for scratch build
    November 2006
Posted by 65 air cav vn on Wednesday, November 22, 2006 4:33 AM
Does anyone know where I can find deck hardware (like bollards etc) and info on scratch bulid and books regarding same? I tried a product today. It is called Maskit Easy. You brush it on parts that you don't want paint to adhere to. Worked pretty good. Check it out. Bought at Micro-Mark. Hank SUPPORT THE TROOPS
    August 2005
Posted by EdGrune on Wednesday, November 22, 2006 8:20 AM
L'Arsenal of France lists a set of assorted open, closed, and roller chocks/fairleads in 1:350 scale resin
Order L'Arsenal direct,  from White Ensign Models in the UK , or from Pacific Front Hobbies or ShipCamouflage.com in the States.
White Ensign also makes a set of PE open and closed chocks & fairleads.
It is simple to scratchbuild some bollards.   All it takes is some fine Evergreen rod (1/2 mm or thereabouts).  Cement two pieces to a strip of plastic (base) standing vertically.  Space them about the rod diameter apart.  Trim to height
