Soleil Royal Heller: improving hull shape
    November 2006
Posted by Papillon on Thursday, November 30, 2006 2:07 PM
To give the underwater part of the hull more substance, I din't try it and it's a rather crude way but it could work.
A. On both hull halves: draw a straight line, well below & paralell to the waterline
B. Saw along that line both hull halves in 2 pieces.
C. Take a wooden board of about 10-12mm thick and glue it in between the sawlines of the 4 plastic hull parts.
D. Sand all below the waterline flush, painting etc.
So, you have added an 10-12mm extra depth to the underwater part of the hull. In fact, you can do a lot in order to improve plastic kits! I have plans to modify the little Airfix HMS Prince into the original dockyard/ Navyboard version, with exposed beams & futtocks below the 1st whale, half open decks etc.; wouldn't that be a nice little cute thing?! One has to open up the closed dummy gunports, build in some sort of gundeck (strips along the inside of the hull) and glue small carriage-like small blocks (drilled) on it in which the dummy guns are to be inserted. Etc, etc.!!
Max.
    May 2003
Posted by jtilley on Thursday, November 30, 2006 3:07 PM
That might work.  Another possible material would be sheet plastic, such as Plexiglas or Perspex.  But the person who tries it is going to have to be somebody other than me.
We dissected the Heller Soleil Royal pretty thoroughly in another thread a couple of months ago.  Here's the link:  /forums/1/678958/ShowPost.aspx#678958 .  I think I said more than my share about the subject on that thread; this kit may be my un-favorite of all time.  I built it once, and regard the two years' effort I put into it as utterly wasted.  But if somebody else, knowing what's wrong with the thing, wants to tackle it, that individual certainly has my best wishes.  To each his (or her) own.
On the other hand, there are quite a few kits out there that come up to a much higher standard.  A week or so ago, having sensed that I was creating the impression that I didn't know how to say anything positive about a plastic sailing ship kit, I started a thread labeled "GOOD sailing ship kits."  It appears a few lines below this one.  There are more than fifty kits on it.  I don't claim for an instant that it's a definitive list - but I do find it interesting that, so far, nobody has suggested that any of the kits on it shouldn't be there.
    November 2006
Posted by Papillon on Thursday, November 30, 2006 6:13 PM
Thanks mr Tilley,
I fully agree with you on wooden & plastic kits; see my other messages posted today (I'm new on this board) and 'have to get rid of my egg' as we say in Holland! And I can imagine you're fed up with that f.....g Sol Roy kit!!
I don't intend either to 'improve the Sol Roy'; when I was 17 I spent a lot of time on it and liked the painting job in particular. However, I can 'recycle' the kit: make rubber molds of the elaborate dercorations for using on other (based on good research) French Baroque ships in about the same scale. Or, you kan use the sternpart of the model as a walldecoration: just take a saw and cut off the sternpart inclusive sidegalleries, glue this on a nice piece of wood, mount it in a frame and hang it on the wall; a nice '3D painting of a baroque ship's stern'!
Max.
