USS Gato SS212 Submarine 1944
Posted by Anonymous on Thursday, December 7, 2006 7:36 PM
Can somone revew this model (Product #05906) Fo me so I can decide weather I should get the one revered in January 2007's issue(USS Gato SS-212 1941) or this one.
 Many thanks.
Posted by cassibill on Thursday, December 7, 2006 8:39 PM
The 1944 version isn't released yet.  The date is TBA according to Stevens International.  Depends on what you want to depict.  If you just want a Gato, it doesn't really matter.  If you want to depict a different boat in the class, you'll have to decide which is closest to want you want.  The conversions for the Haddo, Grunard, and Thresher use the 1941, while the Wahoo uses the '44.  There are details available for both.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by Anonymous on Thursday, December 7, 2006 9:07 PM
Ohh! The Wahoo? Then I might get the 44. That is unless it needs any major modifacations(ie not in the box) because Imm still a beginer modler.
Posted by cassibill on Thursday, December 7, 2006 10:28 PM
Nautilus makes the resin conning tower to show the Wahoo in '42.  Other then that any differences would armament and limberholes. The holes would be easy to do from a couple pics and White Ensign makes any guns you'd need and a PE set.  I heard Iron Bottom Sound has some stuff in the works as well and Nautilus is planning more conversions.  I not as really into ships as I seem.  I'm just big on 1/144 so I've really been following this.
Posted by Anonymous on Friday, December 8, 2006 6:24 AM
Great. I dont know how to work with resin. :(
 And whats a PE set?
    August 2005
Posted by EdGrune on Friday, December 8, 2006 8:11 AM
There is nothing magical or mystical about resin,  excepth that it does not react to normal modeling cements.   You must use cyanoacrylate (CA or 'SuperGlue') or epoxy to attach parts.   Resin cuts with most modeling tools,   sands with most modeling sanding tools, and paints with most model paints.  Resin has the added benefit of being softened and repositioned with hot water.  Resin is able to take fine details,  beter than some injected plastic kits.  Some may claim it to be expensive,  but the costs are quite reasonable for a limited-run item where the production run is measured in tens of units versus thousands of units for an injected plastic kit.
PE stands for photo-etch.    A pattern is etched out of a piece of metal; usually brass, but often nickle-silver or stainless steel.  The etched metal allows finer details than either resin or injected plastic will allow.   Photoetch technolgy is an outgrowth of the printed circuitboard industry.  Photoetched material is flat and must be bent to acheive 3-dimensional objects.   On aircraft models PE may be used to make antennas,  cockpit details, weapon details, or structural items such as jet engine exhaust dampers (i.e. turkey feathers).   On armor models PE is often seen as ammo stowage boxes,  machine gun cradles, realistically thin fenders and brush guards, and surface applique details.   On ships,  photoetch is most often seen as railings and radar screens.   These items cannot be mass manufactured by other means which will capture their light and airyness.
This is a scan of the PE set manufactured by Nautilus Models for their 1:178 scale Revell USS Lionfish conversions
Posted by Anonymous on Friday, December 8, 2006 1:54 PM
But how do you atach resin to Modling plastic?
Posted by Anonymous on Friday, December 8, 2006 2:18 PM
And In light of the Wahoo discovery I think I will brave into aftermarket parts.
 Although from looking at Wahoo Photos it looks like the 1941 version would be a better start.
    August 2005
Posted by EdGrune on Friday, December 8, 2006 2:18 PM
CA or epoxy.  Same for permenantly attaching the PE to either resin or plastic.
White glue can be used on either to tack the parts in place - then go back & lay in a bead of glue to make it permenant.
Posted by Anonymous on Friday, December 8, 2006 2:34 PM
Will Krazy Glue work?
    February 2005
Posted by rokket on Friday, December 8, 2006 7:06 PM
Krazy Glue will be fine, it's a brand name of super glue/Cyanoacrylite
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
Posted by Anonymous on Friday, December 8, 2006 8:18 PM
ok. Its just that I remember trying to used supperglue to repair a prop once on a fighter and it didint work.
    August 2005
Posted by EdGrune on Saturday, December 9, 2006 7:53 AM
CA (Krazy Glue, Super Glue, Zap, etc.) are effective in assembling models, whether the parts be made from plastic, resin, or metal.   However,  CA is a tool.  Like all tools you need to learn how to use them correctly and efficiently.   In your case with the prop and CA, I can't tell you what you did wrong.   Perhaps too much glue,  perhaps too little glue,  perhaps a dirty, ill-fitting joint,  perhaps it moved before the CA set,  perhaps the CA set before the parts were joined, perhaps it was old or poor quality CA.   CA has worked for me making similar repairs.  It is technique,  Technique can be explained, but it must also be practiced and perfected.
Perhaps before you invest in the Gato kit and a similar amount in the Nautilus aftermarket resin conning tower you should invest in a learning kit or two.   Get the Gato & build it out of the box,  but use CA instead of solvent glue.   Next get an inexpensive resin kit and build it.   This one, for example, costs less than the Nautilus conning tower
http://www.finescale.com/fsm/objects/pdf/fpb040422.pdf
And will give you experience in both resin and photoetch assembly.
    December 2003
Posted by scottrc on Saturday, December 9, 2006 7:54 AM
CrazyGlue and most of the brands that you get at the hardware store are generally too thick and cure too fast to be used for resin modeling.  Look for thin, medium, and thick CA glues under brands like ZAP or house brands sold at hobby stores in 1oz and 2oz bottles.
Since I live far from any hobby store, I have been lucky with using Lock Tite brand superglue sold at just about any chain hardware or department store. Lock Tite CA comes in a neat 1oz applicator that last quite a while before it starts to clog up.   They also make a brush on liquid that I just tried that seems to work great in really tight areas.
 Like Ed said though, using CA takes practice, touch, and feel.  It is like painting and you need to develope a technique through experimentation.   I started with a few 1/350 airplane kits from White Ensign and a 1/350 tugboat from Corsair Armada to get the feel on how resin works without sacrifing a lot of costs in case I didn't like it.  Resin is different, especially when incorporating it with styrene, brass, and even wood, but after you work with it, will find that it has some really good qualitites that styrene lacks.
 Scott
Posted by Anonymous on Saturday, December 9, 2006 12:40 PM
Do all resin conversons need PE parts? And how hard is it to work with PE parts?
Posted by Anonymous on Saturday, December 9, 2006 2:32 PM
I plan to try resin with the Gato 1941 because I have a old Apachie I can work on. Allthough I cant finish it because there missing parts. It will still be good training.
Posted by Anonymous on Sunday, December 10, 2006 2:49 PM
How hard is it to work with PE parts?
    December 2003
Posted by scottrc on Monday, December 11, 2006 9:22 AM
PE is not hard to work with, but does require a different mindset and practice.  Unlike plastic modeling where all your parts are 3D, you are taking parts that are 1D and making a 3D part.  This requires some planning and some foresight by studying the plans, pictures, and then visualizing the finished part in your mind.
I found that building with PE was a lot like rigging a sailing ship.  It requires practice in learning how to plan where the parts are to go, working in steps, and then learning the finese of cutting, folding, glueing, and mounting the parts.  Like any new techique, it requires a learning curve and pracitce.  A small resing model like what Ed suggested would be a good started for using PE as well.
 Scott - PE Newbie
Posted by Anonymous on Monday, December 11, 2006 7:58 PM
Agianst all advice I am going to dive in head first into my Wahoo project.
    November 2004
Posted by mkeatingss on Tuesday, December 12, 2006 9:31 AM
 Good for you. Go for it!
You asked around and got the best info you could. Now you've made a decision. Ultimately that's what we all have to do.
And don't wory about failing. You can't! It'll be a fun learning experience, no matter what. You'll learn about model building, history and the technology. And, it'll give you pleasure and satisfaction.
Never forget, the only person who never fails, or screws up somethnig, is the person who never tries anything new or different. There's an old truism that goes, "Your last model will seldom be as good as your next."
Mike K.
    December 2003
Posted by scottrc on Wednesday, December 13, 2006 8:24 AM
Congradulations, you are now just like any number of us who, despite the odds, take on the challange.   Keep us abrest of your progress.
Scott
Posted by Anonymous on Wednesday, December 13, 2006 2:07 PM
Scott
Thank you. In modling I belive if you put your hart and sole ito a project you can do anything.
And I wll keep you informed with my progress but because I dont have a Digicam there wont be any pic's till the end
    August 2005
Posted by EdGrune on Wednesday, December 13, 2006 2:26 PM
you can do anything with deer and fish?  ;-p
Websters Online Dictionary
Main Entry: hart
Pronunciation: 'härt
Function: noun
Etymology: Middle English hert, from Old English heort; akin to Latin cervus hart, Greek keras horn --
chiefly British : the male of the red deer especially when over five years old
Main Entry: 1sole
Pronunciation: 'sOl
Function: noun
Etymology: Middle English, from Anglo-French, from Latin solea sandal, a flatfish
: any of various flatfishes (family Soleidae) having a small mouth, small or rudimentary fins, and small eyes placed close together and including important food fishes (as the European Dover sole); also : any of various mostly market flatfishes (as lemon sole) of other families (as Pleuronectidae)
Posted by Anonymous on Wednesday, December 13, 2006 9:21 PM
Oh dont corect me. Angry [:(!]
Posted by Anonymous on Thursday, December 14, 2006 5:54 PM
For my Wahoo modle I need a color photo of her. It it posible to get one. If so can you post the sight or pic itself.
Thanks in advance Navy1941.
Posted by Anonymous on Friday, December 15, 2006 9:40 PM
I have goten my modle and have allreadt started on it. I am using a mixture of tube and CA gule.
