inpw1 wrote: |
Both ships I have built I have had problems with the rigging on (dont build bi-planes due to the rigging issues either). Any sugestions on how to get it tight the first time would be apriciated. |
There are several options.
The lycra thread was mentioned above. Unravel some of the wife's pantyhose & use that. It superglues well. It also has the benefit of being somewhat forgiving of an accidental finger poke. A similar product is EZ Line. It is a rubberized thread. I got some at the IPMS Nats last year. I know of only one hobby shop that carries it -- check with Bobe's Hobbys in Pensacola, Fla.
Next, Invisible Thread from the sewing depatment. This is a smoke-gray monofilament material. It comes off the spool all curley so stretch it slighlty and run it across a black marker to color it. Cement with CA. It will tighten with the heat from a blown-out match or small soldering iron. The invisible thread method is often recommended for aircraft rigging. Drill small holes at the tops & bottoms of struts and in the fuselage. Run the thread, point to point, through the holes and in & out of the fuselage. Pull tight at each stage and add a drop of CA at each connection.
Stretched sprue is similar. Stretch some sprue to fine threads. Measure & cut. Glue in place with some CA. Tighten with a blown-out match or soldering iron.
I also have used some 0.006 inch stainless steel wire. Measure, cut & glue with CA.
The monofilament, sprue and wire do not react to humidity and stay taut. I rigged a ship with some pantyhose lycra and within a year it had contracted and bent the yardarms. Experiment. Unfortunately also, each of these methods use materials which are way overscale. The 0.006 wire is 2 inches diameter in 1:350 scale. Flag halyards are 3/8 to 1/2 inch (0.0010 to 0.0014 in 1:350 scale). It is a limit that most ship modelers understand and accept.
inpw1 wrote: |
I pointed the wavey lines out to my wife when she painted thwe small boats, but the response was not favorable, so thata the way they are for the sake of my sanity and mariage. |
I understand fully. Keep peace in the family. But maybe some night they will pop themselves off, get repainted, and be reapplied before the next morning. Model room gremlins work that way sometimes.
