Ok... I've finally started this build...
But there are some modifications for the stuffing tube setup I've made...
First is the materials used...
Unfortunately, I wasn't able to acquire some brass tubing for my stuffing tube... the diameters required are just too small... even or local HS don't have 'em...
So after much thought and rummaging on some junk, I've made a possible solution...
first, for the main tube, I used 2 pieces of plastic straw that came with my tetrapak juice drink (cut to conform to the model's hull and to match the exposed length of the shaft (with holes and seams filled with gap-filling super glue), one each propeller shaft) and for its plugs/washers, I rolled a piece of bond paper, and used super glue as adhesive, letting the glue seep to the paper to make it waterproof (I hope so), and AFAIK, super glue soaked paper is impermeable to water and/or oil-based fluids... and also, before the props would go, I'll also put a plastic washer between the tube and the prop for better spin (and better waterproofing I hope)...
and second, I made it to be a "combined stuffing tube and box", meaning, the stuffing tube is connected to the stuffing box which is already molded on the model hull... both of which will be filled with grease...
I've made some trial "dry runs" with the motor turning and the stuffing units without grease to see if the props are turning well, and they are (with some ocassional grinding sounds because the motor is not properly mounted, and the gearbox not secured well)...
later, after the hull is completely done (electronics, paint and all), I'll do some trial floats with the motor running to look for possible leaks...
to ship builders out there... would these mods work? My dad says it will work, since the setup would be waterproof according to his observations...
The Sky is NOT the Limit
