Which etched metal set for the Revell 1/72 Type VIIC?
Posted by Anonymous on Monday, December 18, 2006 1:33 PM
If you had to choose one etched metal set to use on this kit, which one would it be: Eduard, Modelbrass, Yankee Modelworks, or White Ensign?
    February 2005
Posted by rokket on Saturday, December 23, 2006 2:55 AM
I tried to stick to 2, anded up buying almost all and then relesing my own with a partner (which is nwo offered at White Ensign - Vent Set).
Very tricky. Some overlap, but they all have good stuff. Modelbrass really was only about the vent/flood holes, which are a must because it's impossible to cut out those bottom ones and make them look good and thin without beaking them. Eduard has fine detail and metal anti-slip deck bits, the vent set gives you accurate torpedo "cheek" pieces, templates, tensioners and turnbuckles and more, and the other sets have handwheels and various very good bits.
A very personal, biased view: Modelbrass, WEM 1 and WEM vents, Eduard.
Good luck and keep us posted!
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
