Painting question
Painting question
Posted by kp80 on Wednesday, December 20, 2006 7:58 PM
I'm getting ready to paint a Revell T-2 which is partially (mostly) assembled, with a single shade of gray all over.  After that I plan to apply a couple of different washes, then finish off with some weathering pastels for grime, rust, chalking, etc.  Most of the articles I read suggest applying a flat color coat, followed by clear gloss (Future), then the washes, followed by clear flat, then pastels, followed by another coat of clear flat.  I was thinking about applying a gloss color coat, then apply the washes right over that.  This way I can skip the one gloss coat.  Any reason I shouldn't do this?  I have some MM Acryl gloss gray I was thinking of using.  I was thinking that eliminating one coat of something keeps the detail a little sharper.  I have some PE WT doors I'd hate to see buried in paint.  Thanks in advance.
    August 2005
Posted by EdGrune on Wednesday, December 20, 2006 10:07 PM
One of the reasons for the gloss coat before the washes is that the glossiness helps the wash flow into the crevices better.   Also,  the "grainy" particles in a clear flat -- which gives the flat appearance -- will absorb some of the wash color - resulting in a muddy appearance.
I suggest you experiment both ways on a scrap kit and see how each performs.
> The gloss coat also facilitates clean-up of too much wash. It is easier to suck it off with the corner of a paper towel. With the flat - it tends to stay, traped by the flattening agent particles.
    February 2005
Posted by rokket on Thursday, December 21, 2006 1:55 AM
Keep us posted, I'm very interested myself1 Thanks for the idea kp, and the advice, Ed. kp - post some pix when done!
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
    March 2005
Posted by mfsob on Thursday, December 21, 2006 10:10 AM
If you want to try laying down a gloss coat of gray first, to skip having to future a flat coat of gray, I would strongly advise you to experiment on some scraps first.
I tried that with some 1/700 aircraft, and for some reason doing a gloss coat, instead of a flat coat and then coating with Future prior to decaling, just did not work. For me, at least, the gloss coat did no dry with that dead smooth level surface you need to keep decals from silvering. Since that is not an issue with your tanker, try it - but do all the weather on both test pieces as well, to see which looks "better" to you.
Posted by kp80 on Friday, December 22, 2006 10:21 AM
Thanks to all for the advice, I'll let you know how it works out!
    December 2005
Posted by onyxman on Friday, December 22, 2006 12:06 PM
KP,
Sounds like it's coming along!
See my post re Marritime Commission data.
Fred
