MagicSteve: The cord I used for the shrouds was from a company called Artesania Latina sold at my local HobbyTown(NC). The part number was 8144. In hindsight I should have used a larger thread. After starting my shrouds I read that the actual shrouds were 11" in dia.
To get rid of the fuzziness I tried beeswax but I guess I wasn't doing it right. Looked like the glaze on a donut. So I decided to try something a little different. I took a lenght of thread and dabbed a little Testors Rubber Enamel paint on it and smeared it for the lenght of the thread with a cloth. It worked very well. It got rid of the fuzzies and made it more like wire...but not too much.
The fittings were made from a loop I found at Michaels. Not perfect but acceptable.
Wilbur: After securing the deadeye assembly to the shroud I wrapped a small thread around the lower deadeye and passed it through the hole in the channel. I then cemented it into place with CA. If it was a little too long I twisted it up until it gave the correct tension to the shroud. All this has its limitations of course.
I'm glad to hear from others that ratline work takes months to do. The majority of my time was spent on the ratlines. At first it seemed like an impossible task but after I while I could do it in my sleep...Well, just about. Here's a photo that may give you a better idea.
