Weathering a Liberty ship - beyond rust
    March 2005
Posted by mfsob on Sunday, January 14, 2007 12:50 PM
I've started weathering (OK, having some fun with) my 1/700 Liberty ship. I've decided to depict the John Randolph, outbound to Murmansk in convoy PQ 16 in May 1942, as one of the first Liberty ships to make that run. Many of the photos I've found show Liberty ships  incredibly, well, nasty in between trips to the yard. Even though all of them are in black and white, you can tell that almost every square yard of some of them is covered with rust or corrosion of some kind.
Easy enough to do, and I've tried to be restrained, but - what else? I've got a jar of Polly Scale "dust" and am wondering if small amounts, discreetly applied, could simulate the salt encrusted around the bottoms of vertical surfaces. Any other suggestions? Good color references of wartime Liberty ships are rather sparse.
    December 2005
Posted by onyxman on Monday, January 15, 2007 12:11 AM
I've looked at lots of Liberty pics too. Almost every one seems to me to have streaks of soot running down from the scuppers over the outside of the hull. It might be rust, but I think it's more likely soot. Many of them seem to have a lot of scuff marks from lighters and barges coming alongside too.
A ship going to Murmank might also have a lot of ice on the upper works. I have no idea how you would model that.
    June 2006
Posted by Grem56 on Monday, January 15, 2007 12:18 AM
Ice ? Like this ?
Julian Big Smile [:D]
illegal immigrants have always been a problem in the United States. Ask any Indian.....................
Italeri S-100: http://cs.finescale.com/FSMCS/forums/t/112607.aspx?PageIndex=1
Isu-152: http://cs.finescale.com/FSMCS/forums/t/116521.aspx?PageIndex=1
    December 2005
Posted by onyxman on Monday, January 15, 2007 12:23 AM
No, that looks like warm ice. It's more like this:
Big Smile [:D]
By the way, I doubt you could see any salt in 1/700 scale.
    January 2005
Posted by Chris Friedenbach on Tuesday, January 16, 2007 12:10 AM
In addition to general rust and scuffs on the hull one of the most noticeable items of weathering is soot from the stack. The boilers would typically burn pretty cleanly to avoid making smoke, but every day or so you need to blow tubes (basically using steam to blow the soot off of the boiler tubes and out the stack). This leaves flecks of black soot all over anything downwind. In 1/700 scale effect of the flecks scattered on the deck would not be visible, but the top of the signal mast on the flying bridge should be stained black starting several feet below the top of the stack. The top of the charley noble (galley stack) should have similar staining due to the coal smoke.
One other weathering item is staining from the discharges located above the waterline (if you are doing a fully loaded ship they are just barely above it). There are several located on the either side amidships, as well as two aft on the port side under the forward end of the afterhouse. Most of these discharge liquids from either the accommodation drains (deck drains, sinks, and showers) or toilets. There are also a few discharges forward, but they seldom would have anything coming out of them.
One less noticeable (at least in 1/700) item is grease from the cargo runners. They are slushed with a very messy grease that has a habit of leaving black streaks on anything the wire touches, particularly on the rails (when lowering the cargo hook to the pier the runner from the offshore winch usually rubs across the top of the rail).
Regards,
Chris Friedenbach
Crewmember, SS Jeremiah O'Brien
    March 2005
Posted by mfsob on Tuesday, January 16, 2007 10:21 AM
Thanks for the detailed info, Chris ... and no, I am not going to try and simulate soot flakes. I'm not that anal. At least I don't think I am. Now about the color of the discharge from those accomodation drains ...
    January 2005
Posted by Chris Friedenbach on Thursday, January 18, 2007 10:24 PM
The sink/shower drains would be a nice rusty color, but the other ones depend on what the galley put out for lunch...
Regards,
Chris Friedenbach
Crewmember, SS Jeremiah O’Brien
