The Nelson Chequer
    November 2003
The Nelson Chequer
Posted by JoeRugby on Tuesday, February 13, 2007 8:05 AM
Gentlemen,
I am attempting a "what-if" conversion of the Lindberg "Jolly Roger" to a RN sixth rate of 28 guns (I know it sounds familiar but in no way is this the Surprise) of the Napoleonic Wars.
The aforementioned chequer...does it require the gun port lids to be black?  Some of the things I am using as a reference show this may not be the case.
Check out the WW I Special Interest Group @ http://swannysmodels.com/yabb/YaBB.pl?board=WW1SIG
    February 2006
Posted by GeorgeW on Tuesday, February 13, 2007 9:04 AM
I think the answer is not necessarily.
Prior to Trafalgar at one point the gunport lids of Victory were painted yellow ochre, but post Trafalgar the fashion grew for all rates to have the lids black against the Ochre or white strake.
Prior to the painting of ships sides they were payed with rosin a sort of yellowy varnish finish, but were also painted plain yellow, perhaps with black wales.
You really do have a fair amount of choice in the matter
Personally I think your sixth rate would look fine with black main wales, mellow ochre sides, and perhaps black or dark blue topsides.
Whatever you choose  I don't think you will be wrong.
    November 2003
Posted by JoeRugby on Tuesday, February 13, 2007 9:46 AM
I was planning on doing the port lids black, a muted yelow stripe from just aft of the cat heads through the gallery and along the edges of the stern.  Then it will be black down to the yellow with a thin red stripe (al la O'brian's reference, but I can not remember the book.) under the yellow back to black then down to the copper.
I am rescribing the hull to show the panels and then will pull on some Bare Metal Foil for the copper.
Any one else reading this I would appreciate thier suggestions.
