Thanks, all!
In general, I think that modelling for wargaming purposes, when the game is more about the crew and passengers than the ship itself, means compromising on any detail that: a) would impede the temporary placement of based figures on the deck or other flat surface; b) would get in the way of thick and/or clumsy fingers; and/or c) that would be vulnerable to damage.
1. It looks as if the Trumpeter capstan will have to be remodelled or replaced, then. (The bars would have gotten in the way of gaming);
2. OK!;
3. Thanks - the chocks are not a huge impediment, so I'll leave them there; and
4. Thanks, that's what I was thinking, although both approaches beg the question of whether ships really were maintained on 'even keels' such that the keel was parallel to the water surface ... Regardless, that should be a reasonable enough assumption.
New Questions/Observations:
5. I'm waiting for a set of plans and a couple of other references to arrive, but it looks as if Trumpeter made what should have been their Mayflower's halfdeck into a quarterdeck, since some of the bulwarks are incredibly high above the deck. Also, if I remember correctly from a Revell kit of long ago, the space astern of the mainmast was decked over, enclosing the capstan.
6. I will do a search, but are there any recommended Vasa references?
Here's my 'to do' list of Trumpeter Mayflower build changes/redemptions:
a. Replace all spars with wood;
b. Deck with wood;
c. Consider replacing guns with brass and/or pewter sakers or falcons;
d. Remove silly stern detail, and affix a carved heraldic rose (in keeping with the fictional 'Black Rose' name);
e. Consider extending the quarterdeck into a halfdeck;
f. Waterline and cut the hull;
g. Consider elevating the stern chasers;
h. Consider realigning the skewed bowsprit;
i. Detail the bulwarks;
j. Waterline and cut the boat;
k. Reinforce the forecastle and quarterdeck/halfdeck/poopdeck corner strakes for mounting swivel guns;
l. Consider replacing all pins with wood;
Cheers,
vonB.
P.S.: These finescale fora really need a 'reply to thread rather than individual posts' button, as replying to one post temporarily hides the points that others have posted ...
