Lighting up a 1/700 hanger deck?
    August 2005
Posted by mdools288 on Thursday, February 22, 2007 3:49 PM
Hey all,
I got the Trumpeter 1/700 Abe Lincoln for Christmas and I really want to do a bang up job on it so I was thinking about trying to light up the hangar deck like I've seen on some of the 1/350 carriers on here. Has anyone here ever lit up a 1/700 carrier or anything along those lines? I'm trying to figure out which lights to use/how to even begin haha. I was thinking that if I could try to find a very short string of LEDs I would use those, but no luck thus far. Thanks for the help!
Camp BoBo 2010
    August 2005
Posted by mdools288 on Saturday, February 24, 2007 10:50 AM
Guess not...
Camp BoBo 2010
    May 2006
Posted by David Harris on Saturday, February 24, 2007 12:54 PM
Sci Fi modellers tend to be more into adding lighting that anyone else. Maybe pose the question on their forum, or have a google for something along the lines of lighting starship models.
This is one of the links that a search came up with:
http://www.starshipmodeler.com/tech/cj_xmas.htm
Another potential lighting source might come from PC case modding stuff. Cold cathode tubes are probably going to be too big, but had a string type long light about 1 to 2 foot in length (I had a pair in blue, but never fitted them in the end. Imagine that they must be available in white?) If so, you could probably fix one to the ceiling of the hanger deck & I would have thought that it should be pretty much invisible. I did light one up & it ran quite cool so I wouldn't have thought that it would cause any heat related problems. I think they run off 12v DC.
    July 2005
Posted by warhorse3 on Saturday, February 24, 2007 5:30 PM
I am assuming you would be mounting it on a wood base. You could the use fiber optics run from a point in the base up through hull onto the hanger deck overhead pointing the strand ends down to light the deck. Carve a cavity in the base to house the bulbs in a light-tight box. From that point you can run the strands up the port side ahead of the elevator painting them to look like ducting. Using L.E.D.s as the light source would have the advantage of low heat output. Another method thet comes to mind would be using one or two light sheets of the type used to light starship models and model railroad signs and effects. Use an experimentor lighting kit;they normally have colored sheets to cover the e-l sheet giving the color you want. This would vastly simplify wiring and heating concerns. You would simply need to use a plastic sheet that you could drill pinholes through at the right spots to simulate the overhead light fixtures. I hope this gives you a few ideas. Enjoy your buildSmile [:)]
Regards, Bill
