I like the model. 1/700 is a great for ships.
I like the paint specially the deck area. I haven't found a single color that closely matches deck gray, but you are close, and I like it.
The model is just not accurate. That is not your fault it's the manufacturers lack of attention to detail.
I had the same problems you had with the decals with the Dragon model I last built. Plus the red deck line for the 5'' is way to thick regardless. In reality it's a 3'' line with a 21/2'' letter stencil
You did a great job on the VLS. But the CIWS is just huge on the model
The rigging that goes from the mast to the FWD end of the ship is for ceremonial and holidays decorations. It's where we hang our signal pennants for change of command and so on, if you decide to use that make it go aft as well and don't hang them from the SPS 67.( that thing its quite expensive J )
I don't believe is so bad that you dint put a netting system on the aft end of the ship. See we have to lower them down when ever we have flight ops so, I believe that you can greatly improve on the model if you practice and place them horizontally around the flight deck area and hoist the H flag for helo ops !
The one thing I cant stand is the shape of the smoke stacks they are just not close to the actual thing at all. They should at least be shorter and have less of that flower shape on the top. Paint them Jet exhaust gray and also paint the vents on the sides. (Not back, but a darker gray but, lighter than the deck a wash will do).
Your harpoon launchers are great looking and aiming in the correct configuration. (People often miss that detail).
Did your model come with the torpedo launcher tubes? If you have them add them. It will make it up to date. Port and STBD.
You see those two octagon shapes on eider side of the CIWS. They are radars and they are never ever ever painted over so they always look pail in comparison to the rest of the ship. Once again a wash will do (light gray, lighter than the hall but not as light as the VLS)
The radar on the weather deck above the bridge. Paint them gaze gray.
You have a good model and the thing is that you can improve on it I like it a lot. Is too bad that the decals fell apart.
Take your time you have a great start.!
ON MY TO DO LIST:
1976 Chevy Nova
F-106 Delta Dart
