Murphy was a modeler
    June 2007
Posted by styrenegyrene on Saturday, July 28, 2007 1:22 AM
Any holding device - tweezers, clamp, etc. - that delivers enough grip to hold the part will break the part.
A three-cent resin or photo-etched part will fall and hide until about two hours after you have spent $10.00 on a complete spare set.
The shelf life of paint is inversely propotional to the cost.
Cats LOVE models!
The curing rate for glue between the part and the tweezers is about 10X the rate for glue between the parts you are trying to bond.
What else?  I bet y'all have got some doozies.
Turning styrene into fantasies for 50 years!
    December 2005
Posted by onyxman on Saturday, July 28, 2007 7:58 AM
CA glue will develop a steel-like bond to anything it contacts, except what you want it to bond to. ( I guess that's the same as your last one)
    July 2013
Posted by DURR on Saturday, July 28, 2007 4:15 PM
how about you find you tube of misplaced glue 5 min after you come home with a new tube
Posted by millard on Saturday, July 28, 2007 10:59 PM
You've held a part in place for a long time to get the glue to bond.Then you see that you've put it on upside down or backwards.
Rod
    June 2007
Posted by styrenegyrene on Sunday, July 29, 2007 11:53 AM
A part will be attached to the sprue at a point carefully designed to do the maximum damage to delicate details.
If part "A" must, absolutely, without question - really, REALLY MUST - be attached BEFORE part "B," the reverse is also true.
A Southwestern US law:  The more tightly you seal your display case, the more dust will get in.
Corrollary to that:  If dust settles at some rate, "R", on the diecast piece of junk your brother-in-law gave you on Groundhog Day, it will settle at "R-squared" on the finest piece of work you've ever done.
The day after you finish a model you've based on that super-accurate and authentic [need I add expensive?] reference work, someone will post irrefutable proof that it's baloney.
    December 2003
Posted by scottrc on Monday, July 30, 2007 12:06 PM
Same will be said if you scratchbuilt every part and detail on this model, only to have a complete kit come out in the same month you have finished your scratchbuilt one.
    July 2013
Posted by DURR on Monday, July 30, 2007 12:17 PM
you buy a model for 49.99 and find out the next day  someone is selling it for 32.50
    February 2005
Posted by rokket on Tuesday, July 31, 2007 7:12 AM
These are all gems and this needs to be a sticky!
This isn't as clever a the others, but I have found it too true:
Any irreplaceable part (scratchbuilt or expensive PE) will spring from tweezers and break new ground in Physics, finding a doorway into another dimension.
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
Posted by CapnMac82 on Tuesday, July 31, 2007 3:51 PM
While researching, you will find reference after reference on steam power plants for ships' boats (even Imperial Nepalese Navy Admiral's Barges) in endless, repetitive supply.  This will appear to be to the exclusion of what you are seeking information about.
Until you try to find that info on Imperial Russian Steam Launches for someone under time pressure . . . ('could'a sworn there was 15 dozen monographs las' time I looked . . . )
Aftermarket items, even short-run cottage items will not appear until you have clumsily decided to show off your "well, that's going to have to good enough for now" hack scratch builds.
(To that, let me appologize, it's probably my fault that there is not aftermarket 1/32 or 1/32 bar armor for VN Riverine craft--I just can't pull the trigger to lead with my embarassment first  <g>)
    November 2006
Posted by ww2modeler on Tuesday, July 31, 2007 5:22 PM
Like in the article in the latest FSM, used parts from a A and C Mustang to make a B and then Tamiya came out with one.
You go to the store to pick up paint, look at the glue and say, I don't need this, I got a full tube at home.
You go home, you use the glue for 5 minutes, and a hole pops in it!!!!!!!!!!
David
On the bench:
1/35 Tamiya M26 Pershing-0%
1/144 Minicraft P-38J Lightning-50%
Numerous 1/35 scale figures in various stages if completion.
    June 2007
Posted by styrenegyrene on Wednesday, August 1, 2007 12:05 AM
quoth CapnMac82:
Yup.  I finished a B-17 a while back, and afterward, someone asked me for provenance on something I'd done on the kit.  I'll be dipped if I can find any of the dozen or so photos of it!
    March 2007
Posted by kcmat on Wednesday, August 1, 2007 12:42 AM
 Hahahaha! This is what I was going to add as well!
Let a black part fall on a snow white carpet and you'll play hell finding it. But let a needle fall and you'll be hopping on one foot in no time.
http://www.myspace.com/madmat77
Posted by CapnMac82 on Wednesday, August 1, 2007 5:47 PM
LoL!  Used to have a great huge threatening to bury a person stack of After the Battle.  Never could find the photos in them that I remembered seeing.  Cured that problem by selling'em off <g>.
I just now remember another Murphy.  If you have to drill holes to mount things for specific versions/items/whatever--you will forget to do that only after having achieved the most flawless seam & joints possible.  Then, when you temp fate and sand the finish off jsut bit past bare plastic to get the holes to barely show through as halos--you'll drill out the wrong ones <sigh>.  (What do you mean, there's no such thing as a transitional A-7D/E?)
    June 2007
Posted by jazzy_jeff on Wednesday, August 1, 2007 10:58 PM
no part is too large to lose
    March 2004
Posted by DanCooper on Thursday, August 2, 2007 5:42 AM
How true that can be : I misplaced a 3 foot long hull for an rc hovercraft once on the attick, and after 7 years, it's still missing Banged Head [banghead]
On the bench : Revell's 1/125 RV Calypso
    January 2003
Posted by leemitcheltree on Thursday, August 2, 2007 9:44 PM
That mysteriously missing (but *essential*) part you've been searching for (for HOURS)..... WILL magically re-appear......about 5 minutes AFTER you finish scratchbuilding a new one........
I hate Murphy......
Cheers, LeeTree
Remember, Safety Fast!!!
Posted by Anonymous on Friday, August 3, 2007 2:35 PM
Carefully removing a part from the sprue trying not damage it will always result in it flying through the air and vanishing into a wormhole.
    March 2007
Posted by bondoman on Friday, August 3, 2007 6:00 PM
Regardless of the size of the workbench, there will always be exactly two (2) square feet of clear work area.
    June 2007
Posted by styrenegyrene on Monday, August 6, 2007 12:20 AM
Two sqare feet?  How the devil do you manage that?  I don't think I've ever had half that.  But here's another one of Murphy's jewels:
No matter how much crap you have on your bench, the tool, paint, or part you need is never there before the glue dries.
    March 2007
Posted by bondoman on Monday, August 6, 2007 1:04 AM
Thats what my wife said when she went to do her nails!! Mea culpa
    March 2004
Posted by laffmakr on Wednesday, August 8, 2007 12:10 PM
Instant set glue won't.
No matter what color the part, when it's dropped on the floor it instantly is transformed into the finest camoflage scheme that will render it totally invisible.
Parts dropped will always roll into the most inaccessible point in the area.
    June 2003
Posted by Duke Maddog on Wednesday, August 8, 2007 2:39 PM
When applying kicker to a CA-glued part to instantly set it, your hand holding the part in place will invariably jerk just as the kicker hits the CA glue, drying it in the wrong place/position. This will cause you to have to cut it off and repair the damage done upon removal.
Corrollary to this Law: The damage done to the surrounding area upon removal of an improperly glued part will grow exponentially to the amount of detail/number of other small parts in the same area as the one removed.
    August 2007
Posted by BraniffBuff on Wednesday, August 8, 2007 3:43 PM
A hobby knife/scalpel which falls off the work table will always fall blade down. This invariably occurs after a new blade has been affixed and while the modeler is barefoot. Ouch!
Michael McMurtrey IPMS-USA #1746 Carrollton, TX
    June 2007
Posted by styrenegyrene on Thursday, August 9, 2007 10:18 AM
The more literary, lucid, enjoyable, and generally fascinating a reference book is, the more suspect its veracity.
    September 2003
Posted by roadkill_275 on Thursday, August 9, 2007 3:03 PM
The shelf holding the best piece of work you have ever done in your life will collapse exactly 15 minutes after placing said piece on it. The amount of damage done to said piece will be in proportion to the amount of time spent on said piece.
Kevin M. Bodkins "Meddle not in the affairs of dragons, for thou art crunchy and taste good with ketchup" American By Birth, Southern By the Grace of God! www.milavia.com Christian Modelers For McCain
    October 2005
Posted by CG Bob on Monday, August 13, 2007 11:28 PM
Murphy, and his assistant Captain Chaos bit my rear this weekend at an r/c scale ship regatta.
On an r/c model, the problem will always be the most in-accessible moving part; which requires a strong light, small tools, and a very narrow work area.
The setup: The subject is a 51" long model of a 205' ATF/WMEC, which has been running nicely for about 8 years.  The model is about 25 feet out in the lake, I advance the throttle a little more and the motor revs up, but the ship doesn't move.  Fortunately, the wind is blowing towards my position on shore, and I retreive the model in about 10 minutes.  During the wait, the 3 other captains running boats ask me what's wrong.  How the heck do I know, I ain't in the engine room on the model.  Past experience tells me: 1 - the drive nubs on the nylon dog bone broke off; 2 - the set screw for the u-joint loosened up (not hardly with all of the Locktite); or 3 -the stainless steel prop shaft broke (not likely).
The cause:  The drive nubs on one end of the dog bone broke.
The repair:  I have a spare dog bone to install.  I have to remove the u-joint from the prop shaft to install the dog bone.  Removing the u-joint requires snaking a 1/16" allen wrench thru a 1/4" space to hit the u-joint 2" under the deck at the stern of the model.  What is normally a 10 minute repair job takes me about an hour because of the idiots who keep stopping by to ask what's wrong.  The last person who asked almost got the model shoved up their stern tube, and I was asked to take a stress time out.
    April 2004
Posted by Jon_a_its on Tuesday, August 14, 2007 9:20 AM
How to find that missing tool:
but it's replacement & it will turn up minutes after you start using the new one, or after you loose the receipt! (bill of sale)
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    June 2003
Posted by Beau Mansfield on Tuesday, August 14, 2007 10:45 AM
I had just finished air brushing a number of parts for a large model I was making and I had them outside on the balcony of a friend apartment, when the wind got up well as you can imagine all hell broke loose.
One part went over the balcony and landed in the grass below.
So I thought no problem.
All I had to do was go down stairs and pick it up.
Not so, I looked for nearly an hour before I eventually asked a guy who was working around the building if he by any chance had seen the piece, keeping in mind it was about half an inch square in size.
His reply was yes, it is in front of you.
There really is no answer to that.
Regards,
Beau.
    June 2007
Posted by styrenegyrene on Thursday, August 16, 2007 11:01 PM
There have been several posts here about dropped parts.  Here's a true story.  Last night, I dropped a hand-made part on the floor. It was about 5/8" across, but .020 thick, painted white on both sides.  It fell on a clean, bare concrete floor, and dropped right between my knees.  I looked for that little turkey for 20 minutes before I found it.  Using the old technique of getting a few feet from impact zone and getting my eye as close to the floor as possible, I spotted it.
It had landed on its edge - that .020" edge! - and was leaning against the cord for my compressor - the only white object within 10 feet.  After I spotted it, I went back and looked down on it, and even knowing where it was, I couldn't see it from two feet up.
I thought, "Murphy, you sucker!  You nearly got me!"
    March 2004
Posted by DanCooper on Saturday, August 18, 2007 2:11 PM
And now the truth about Murphy :
 Some people might think Murphy is (or was) a phychologist or even mathematician, this however not true.
 Some people think that "Murphy's Law" says :"Whatever can go wrong, will go wrong", that is equally not true (although te result is the same).
Murphy never "made" a law, nor was he studying the above kind of things.
So : Who's Murphy ?   Well, allbeit unintentionally, the title of this tread is not that far off, Murphy was a chiefengineer for a major aircraft company.
So, why "Murphy's Law" ? Being chief engineer makes you work with people who, well are not always the right person for the right job.  Murphy must have been a very conscious and dedicated coworker for the company and having to work with people that constantly make mistakes isn't that easy.
So, one day, our good old friend mr Murphy was walking into the hangar where a new plane was being constructed, when he saw a piece of equipement having been installed upside down.  Having a bad day or something he went berserck and started shouting as who had installed that equipement.  A little later he walked into he's office, saying to he's co-workers :" argh, ingeneers, whatever they can install wrong, they will do so"
So, the real law of Murphy, translated into modelling actually says :
"Whatever you will do wrong, you will do wrong"
Post Based on an article in "Kijk" a popular scientific magazine in Holland.
