I've used Smooth-On products with success. I've never used their clear resin
http://tb.smodev.com/tb/uploads/Crystal_Clear_200_Series_(202,_204).pdf
Their 202 material casts to 1/16th inch, so casting aircraft wings may be too fine.
Note too this stuff says that it is not for home use and a NIOSH respirator should be used.
I've also heard that effective clear casting requires the use of a pressure pot -- and that the resin is a slow reacting product -- i.e. one shot a day.
Not to rain on your parade -- but you might want to check the Material Safety Data Sheet and product info
