Quick & Easy = make ocean troughts and valleys with something like celluclay (mix water and elmers white glue about 50/50 or so, add blue acrylic paint for a pre-dye) schmeer it on whatever your using for a base. Have fun it's like first grade! Sculpt your ocean, have the waves going as you like- storm & high seas. calm & ripple, whatever. Know how to put iceing on a cake? Very similar stuff. Now that your celluclay or whatever ocean has been formed and is dry, go and cover it with a coat of clear gel medium. It goes on white but dries clear (did I say thin coat?) you can see your blue celluclay depths. You will notice while spreading the gel it (like cake iceing) form little tufts or spikes when you lift the popsicle stick, use these tufts to form whitecaps, curling waves, bow waves, wake prop wash, whatever you need. You can build up waves by using several coats of gel in that area. When you've applied the gel wavws you can dye them with an acrylic color wash, or after they dry outright paint the suckers with acrylics (or oils I suppose) to get the frothy, foam and deep dark trough. HooHa! When ya get it how you want it, let dry, give it and around the waterline of the ship a coupla coats of future floor polish an yer good to go. Have fun... go play in the ocean... G.L. |
