Fonderie Miniatures LCVP
    December 2006
Posted by Lord Darth Beavis on Monday, August 20, 2007 7:08 AM
Hi, everyone.
I have started on the Fonderie Miniatures LCVP, and could use some advice.  I am most puzzled as to how the rear deck fits in, as it appears to be too wide for the ribs.
Should I file th ribs to make room, or do I file the deck?  Reason I'm asking is, I'm a measure 30 times, cut once, then cuss a blue streak because I didn't measure right.Sign - With Stupid [#wstupid]
Anybody else out there that tried this kit?  From the reviews, there were...issues with the molding of the kit.  Mine appears to be pretty well molded, thank the mold gods!
Anybody?
Anybody?
Bueller?
I lied to get the job. They lied about the job. I'd say we're even. I hear...stupid people! Member of the Global Conspiracy since 2007
    April 2004
Posted by Jon_a_its on Monday, August 20, 2007 1:08 PM
Doesn't matter, the fit is awful on all the parts!
I taped the hull & deck front & rear, turned it upside down on the bench, then pressed the hull down to 'spread' the hull sides out to meet the raised 'lip' & super glued as I went along.
Before that I drilled 11 holes along each edge to take mounting pins for the rope.
Mine is currently 'resting' waiting for inspiration.... I'll look up some refs & WIP for you...
How about a deal, I'll finish mine if you do likewise, no rush, round here they call me 'glacier' Blush [:I]
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    December 2006
Posted by Lord Darth Beavis on Tuesday, August 21, 2007 10:42 PM
I'm game.  It might take me the rest of this year, though...and maybe most of the next!Laugh [(-D]  I didn't think mine had that many fit problems, but, I'm still thrashing on it, so I'm sure they will rear their ugly heads.
 So, Jon, what DID you do for the deck?  Also, did your kit have multiple sprues for the deck pieces?  Mine has enough parts to do 2 decks, and 2 engine compartments!  Not that I'm complaining, mind.Big Smile [:D]
    April 2004
Posted by Jon_a_its on Wednesday, August 22, 2007 4:05 AM
No worries on the timescale mate 3 months is a QUICK build for me!
I'll take some pics on my Work (not) In Progress, over next few days, If I remember my Photobucket pasword!
Jon
Don't feed the CM!
    April 2004
Posted by Jon_a_its on Wednesday, September 5, 2007 10:09 AM
Haven't forgotten - been a 'secret shopper' for hospital food,
will be on the case in a week or so, but WILL be on the case soon!
Don't feed the CM!
    April 2004
Posted by Jon_a_its on Tuesday, September 11, 2007 9:04 AM
OK
Uploaded some pics to photobucket:
Usefull drawing of lca, sorry didn't note book title, shows winch runs, & 11 loops for side ropes
red indicates additions to sides & holes for loops
Small Parts, these are duplicated, & need to be!, the funnels & vents were drilled out, props awful!
strip plastic, as indicated in instructions, & necessary to cover gaps!
Rear, holes indicate where I drilled out location points for fittings & engine exhausts,
I erm... made a pigs ear of gluing the back panel to sides, so much sanding needed!
Much filler! Parts undercoated with Testors Haze Grey & Deck Blue for test purposes.
enjoy!
Don't feed the CM!
    December 2006
Posted by Lord Darth Beavis on Saturday, September 15, 2007 9:57 PM
Looking good, Jon!  I've never seen the LCA kit.  I've been pondering getting the Italeri LCM, if for no other reason than inspiration.  The LCVP is a real head-scratcher, when you look at the size of the parts versus where they have to go...Confused [%-)]
Maybe it's like a TARDIS, bigger on the inside than outside!Laugh [(-D]
    April 2004
Posted by Jon_a_its on Sunday, September 16, 2007 2:39 PM
Italeri LCVP a snap!
Most difficult parts:
Observe the build instructions for the Hull ribs carefully & methodically
joining the deck to the hull sides due to the length of it,
painting the life belt rings, I left mine just white,
Running the loading ramp winch rigging
& sanding off the awfull mess I made spraying Tamiya Treacle off the hull, I switched to Vallejo soon after & binned most of my Tamiya paints
Enjoy it as a good build, & next up after the LCA the LCT, I fancy 'rippled' hull sides!
Don't feed the CM!
