Liberty Ship Hull Plating
    August 2007
Posted by BraniffBuff on Tuesday, September 18, 2007 12:02 PM
Does anyone have a hull plating plan for a Liberty Ship?
Michael McMurtrey IPMS-USA #1746 Carrollton, TX
    August 2005
Posted by EdGrune on Tuesday, September 18, 2007 1:17 PM
Maryland Silver
http://marylandsilver.com/books.htm
Contact Duane Borchers and ask about item BK050. It lists the shell plating in the contents.
Note that the book addresses the Liberties built at Bethlehem Steel Baltimore, MD and JA Jones Brunswick, GA.   Other yards WILL vary
    March 2005
Posted by mfsob on Tuesday, September 18, 2007 9:44 PM
Another consideration is what scale - in 1/700 about all you can do is present the general suggestion of plating.
    August 2007
Posted by BraniffBuff on Tuesday, September 18, 2007 10:34 PM
Model is the 1/350 Trumpeter kit.
Posted by AndrewGorman on Tuesday, September 18, 2007 10:53 PM
Liberty ships were welded, so there's not much to see, but here are some pictures of the Jermiah O'Brien in drydock:
http://smmlonline.com/reference/walkabouts/liberty/obrien_drydock.html
Hope this helps!
Andrew
    March 2005
Posted by mfsob on Saturday, September 22, 2007 7:37 AM
OK, at that scale, I would think the tape method would give you enough of an effect. Basically you will want to do long parallel lines of tape following the curve of the hull from bow to stern (eyeball the width of each by studying reference pictures, and remember to curve up near the bow), and then remove every other one. Spray the hull your base color, the remove the remaining tape, and spray a second coat. That should give you a subtle line between the twice-painted areas, and you can go from there.
    December 2005
Posted by onyxman on Saturday, September 22, 2007 10:44 AM
But as Andrew points out, because of the welded construction, the plating strakes aren't too obvious. Looking at pictures, soot stainss and scuff marks along the waterline where barges and lighters might have come alongside are more obvious than the plating.
    March 2005
Posted by mfsob on Sunday, September 23, 2007 5:36 PM
I'd have to disagree about them not being too obvious, although as with anything it's easy to grossly overdo it when attempting to recreate it on a scale model. Remember, Liberty ships were built under wartime conditions, where speed was everything and the aestethics of butting together the sheets of steel to get nice smooth finished surfaces wasn't even considered. If you look at these pictures of the O'Brien in drydock, the lines are fairly prominent even when painted gray:
http://smmlonline.com/reference/walkabouts/liberty/obrien13.jpg
http://smmlonline.com/reference/walkabouts/liberty/obrien03.jpg
http://smmlonline.com/reference/walkabouts/liberty/obrien41.jpg
Just my 2 cents worth. Personally, since I build 1/700 ships, I haven't found it within my meager abilities to try and replicate the effect, but I would be tempted to give it a go in 1/350.
