Chuck Fan brings up what we were taught in hull & armament design class.
The other factor to consider is that in the big guns, you jsut about can't fire straight ahead anyway (there's "stuff" or personnell forward that will get either carried away or injured in the middle 10-15º of the centerline). The typical "B" turret also needs to be trained off some amount, too, or firing its guns is deletiroous to the "A" turret johnnies.
Now, an "ambush" T crossing, where it's shoot or sink, well, that's different. However, when your guns range out to 20-30nm, you rarely have that sort of situation. Which means you can put the helm over enough to train enough guns at the bad guys to engage them thoroughly.
Mostly. It's a complicated chess game of vector analysis and third-order curve geometries.
Now, the only tricky thing about this A140X is that the balance of secondary turrets may be off a tad. Even with all of those monster 18" rifles forward, it's right handy to have something in the 5-6" bore that fires rather rapidly in case you are closing with a destroyer or light cruiser full up of torpedos . . .
