DD-557 wrote: |
Ed - Thanks for your input and the pointer to the FSM article on "Building a Resin Sub Chaser". Your suggestions make sense and the cost of the PC-461 class SC looks reasonable for a first build after reading the article. Now I haven't added in the extra cost of the other items that Phil Kirchmeiser used, but they are items that could be used on following projects and I'd guess they would not add that much additional expense to the project. I'll sure give it serious consideration for my first attempt. |
From the parts & sources list in the article ...
The styrene strip and sheet is something which many modelers have at their desks to scratchbuild, repair or replace kit items. A pack of Evergreen costs less than 3 bucks each.
K&S wire -- some brass wire is included in the kit, but like the Evergreen more or different sizes are often needed. Again its a stock item at many workbenches.
Bare Metal Foil -- I have some which I use for masking clear canopies. It comes in handy if you have it, but you can often make do with other handy materials (Post-it Notes, kitchen aluminum foil, Evergreen plastic (see above)
Hold-n-Fold tool. Tools are nice. I have a lot of them. I have a Hold-n-Fold. The Etchmate is similar. But such a tool is not required. You can make folds just as easily using a pair of razor blades opposed to one another. Place one over the photoetch part and slide the other under. Raise the lower one in a hingeing motion to make a bend. It comes easily with just a bit of practice.
The ISW kit comes with the PE which you will need, as does the YMW Johnston kit. Extra PE is handy to have but not a requirement.
YMW makes WWII decals, as does ISW, and the Resin Shipyard. A set of hull numbers is often all which is needed to differentiate one ship from another.
