Replacing 1/200 Yamato Deck
    October 2005
Posted by usmc1371 on Monday, November 5, 2007 2:57 PM
Hey guys,
I have Nichimo's 1/200 Yamato (got it free, jealous?) and when I start it, I want to replace the deck with real wood.  I plan on laminating the wood deck onto the plastic one after the plastic deck has been sanded smooth.  Do you think 1/32" basswood is too thin to scribe the deck planks onto?  Would 1/16" be better?  Any comments would be welcomed.
Jesse
    August 2005
Posted by EdGrune on Monday, November 5, 2007 4:22 PM
Don't scribe.  Add/replace each deckboard, piece-by-piece, with a length of wood strip stock.  1/32 inch is probably preferred.
Be sure that you carefully cut all of the deck fittings off the plastic deck and catalog their locations before you sand the deck.  After the wood is added replace the fittings in their original locations.
    March 2007
Posted by stretchie on Monday, November 5, 2007 6:39 PM
 usmc1371 wrote:
Hey guys,
nope...... Tongue [:P]
Big Smile [:D] great...another model i've gotta check out......... Sigh [sigh]
you will post pictures....yes???? Smile [:)]
Big Smile [:D]
    October 2005
Posted by usmc1371 on Monday, November 5, 2007 10:58 PM
Thanks.  Why do suggest not scribing?  Wouldn't be hard to keep the individual planks straight? Where's a good place to order that would from?  What type should I order - birch, basswood, etc?  Between buying the photoetch and wood, and building the display stand / battery compartment, it'll be a while before any pictures are posted.
Jesse
    March 2004
Posted by Gerarddm on Monday, November 5, 2007 11:20 PM
Jesse, when you scribe you run the risk of your scribigng tool going off course and followig the grain. And unless your scribing is absolutely perfectly parallel all the time, it'll look very funky.
Bite the bullet, lay planking as it was meant to be laid. It'll look MUCH better, especially at that scale.
Gerard> WA State Current: 1/700 What-If Railgun Battlecruiser 1/700 Admiralty COURAGEOUS battlecruiser
    May 2003
Posted by jtilley on Monday, November 5, 2007 11:44 PM
Basswood is a decent, ok wood for this purpose.  Birch is probably a bit better, in that it's harder.  (Basswood tends to be a little fuzzy - great if you're going to paint it, but not so great if you aren't.)
My personal favorite material for deck planking (speaking as a sailing ship fan), though, is holly veneer.  Holly is wonderful stuff - extremely hard, with a beautiful, fine grain that, with a little help from stain, actually looks like miniaturized wood.  Terrific stuff.  It's kind of hard to find; here's a source:  www.constantines.com.
The big advantage to basswood, of course, is that you can buy it already milled in strips.  (The smallest size carried by most dealers is 1/32" x 1/32"; if you've got a local hobby shop that caters to model railroaders, you may be able to find some slightly smaller sizes in HO "scale lumber.")  Veneer (either birch or holly) is considerably cheaper, but you have to cut the strips yourself.  I don't recommend trying to do it with a knife; it's next to impossible to get straight edges and uniform widths that way.  But if you have access to a miniature table saw, you can rip out enough deck planks for the model - in whatever width you want - in about half an hour.
My favorite adhesive for attaching wood planks to plastic parts is old-fashioned tube-type plastic cement.  (The last time I did it, I used good ol' no-longer-available Revell "Type S," but I imagine Testor's would work ok.)  The principle is that the cement softens the plastic and soaks into the wood.  The model in my avatar has styrene hull planking cemented to a carved basswood hull, and has held up perfectly well for about 25 years.
Two other small tips.  One - before you lay each plank, run a fairly hard pencil around all four edges of it.  That will produce a fine, dark grey line around each plank, and the line will survive any scraping or sanding.  Two - when you've finished laying and staining the deck (I recommend "Driftwood" color stain, from Olympic), give it a thin coat of white shellac, dilluted almost beyond recognition with denatured alcohol.  The shellac will, to all intents and purposes, be invisible; if you dillute it properly it won't add any gloss.  It will, however, make the wood impervious to any paint that inadvertently gets splashed on it, and resistant to other brutal accidents that may befall it before the model's finished.
Hope that helps a little.  Good luck.
