Source for very thin wire
    January 2005
Posted by steves on Sunday, November 18, 2007 10:18 PM
Does anyone know of a source, preferably in the US, for very thin brass wire-.004" or thinner?
Steve Sobieralski, Tampa Bay Ship Model Society
    May 2003
Posted by jtilley on Sunday, November 18, 2007 11:00 PM
A model railroad company called Detail Associates sells straight lengths of brass wire in foot-long lengths, packaged in plastic bags by the dozen.  I don't remember the smallest diameter in the line, but I think it it's smaller than .005".  It's fairly common stuff in hobby shops that cater to model railroaders.  On the web, I'm pretty sure the big railroader's supply firm, Walthers' (www.walthers.com) carries it.
If the wire doesn't have to be brass, a good, cheap way to get hold of really fine stuff is to buy some twisted electrical wire and untwist it.  The stuff that's used for such things as stereo earphone cords (the little tiny ones that are used for portable CD players, for instance) is incredibly fine copper wire.
Hope that helps a little.  Good luck.
Later edit:  I checked the Detail Associates listing on the Walthers site.  The smallest diameter brass wire I could find is .006."  I also checked the Small Parts, Inc. catalog.  No luck there either.  Sorry about that.  Anybody else got any better ideas?
    June 2005
Posted by Powder Monkey on Monday, November 19, 2007 9:41 AM
Mcmaster Carr has a lot of wire. http://www.mcmaster.com/. Type wire into the search box. The finest wire is Ni Chrome, it goes as thin as 0.0031". There is stainless wire down to 0.005".
    January 2005
Posted by steves on Monday, November 19, 2007 10:46 AM
Powder Monkey,
Thank you for that website.   They have some reasonaby priced copper wire in both .003 and .004 sizes which should meet my needs.  I had purchased some 1/192 scale photoetched railing stanchions from Tom's Modelworks to use on a project and yesterday I discovered the only thing I had that was small enough to pass through the tiny holes in these stanchions was a hair from my head.  The Detail Associates .006 wire that jtilley mentioned works great with the Bluejacket stanchions I have used in the past, but was too large for these and some .005 wire I had would not work either.
    August 2005
Posted by EdGrune on Monday, November 19, 2007 11:25 AM
Check the fly tying shops & online stores for fly tying silk.
A trick I learned from Don Pruel of J&D Productions, a professions ship modelmaker, was to use fly tying silk to run the lifelines between individual PE stanchions
http://www.jdproduct.com/
    May 2003
Posted by jtilley on Monday, November 19, 2007 4:55 PM
My initial response in this thread (or maybe we should say, this wire?  Sorry.) was based on the specific mention of brass wire.  For lifelines, something softer probably would be just as good - if not better.
I've got a spool of nickel-chromium wire, about .002 in diameter, that a friend found in a military surplus store about 25 years ago.  I have no idea how many hundreds of yards are left on it - probably enough to last me the rest of my life (which is just as well, since I also have no idea where to find any more of it).  It's really nice stuff for applications that don't require it to be particularly stiff.  I used it for the ratlines on the model of the frigate Hancock that's show in my avatar; it's soft enough to tie in a clove hitch, but stiff enough to be shaped so it looks like it's sagging between the shrouds.  I suspect individual strands from the earphone wires I mentioned earlier would work as well, or nearly so.
    January 2005
Posted by steves on Tuesday, November 20, 2007 9:37 AM
I would actually prefer to use a stiff wire for this application as it imparts a usefull degree of strentgh and rigidity to a pretty delicate assembly.  I originally asked about brass wire because that's what I have used it in the past, however brass is apparently not available under .006" so I guess I will give the copper wire a try.
    May 2003
Posted by jtilley on Tuesday, November 20, 2007 4:12 PM
I think you'll like the copper wire (or, for that matter, the nichrome).  It's soft enough that you can shape it to "sag" a little between the stanchions (if you're dealing with a wire or chain railing).  If it has any kinks in it when you get it, try the old package-wrapper's trick:  draw the wire over the back edge of a knife blade.
MJH
    April 2005
Posted by MJH on Tuesday, November 20, 2007 5:03 PM
A great source for ultra-thin wire is defunct electronic equipment - small solenoids, speaker coils, radio antenna coils etc.  Can't always be certain exactly what you'll get of course.  It's also enamelled for insulation though whether that affects its usefulness I couldn't say, but at least it's free.
Michael
    November 2004
Posted by rockythegoat on Friday, November 23, 2007 11:14 AM
I know you want wire for the strength and rigidity for the part you are working on, so my comment won't apply for that application, although, the item I'll mention fits the very thin requirement.
"Invisible Thread" by Sulky (you can get it at sewing, craft, or quilt stores) comes in several colors, is very thin, pretty strong, and looks prototypically small down into 1/700 scale or so, for a lot of rigging purposes.
"Beer is proof that God loves us and wants us to be happy." Ben Franklin
    January 2005
Posted by steves on Friday, November 23, 2007 8:37 PM
Thanks very much to everyone who responded to my question about thin wire.  I ended up ordering two rolls of copper wire of .003" and .004" from the website that Powder Monkey suggested.   I had thought that the .004" would work, but it turns out that the holes in these PE stanchions are so small that even that was too large so I was glad I had ordered the .003" wire, which does work.
    November 2004
Posted by hwells on Wednesday, November 28, 2007 1:00 PM
Hey Steve, I have some old blinker solenoid switch type thingys that I 'collected' when I was working at a semi truck salvage yard that I will give you. They have very fine copper wire in them, just about the diameter you need. PM me if you want them, and we can exchange info.
 Henry
'Go ahead, poke it with a stick, it ain't gonna bite'
    March 2007
Posted by searat12 on Wednesday, November 28, 2007 2:35 PM
A good fly-tying shop is the place to go, as very fine brass wire is used in a number of fly patterns.  I bought a spool of brass wire at one in Boston years ago for fly-tying, and found it was also perfect for rigging 1/72 scale WW1 airplanes (you can even get flat and oval cross-section wire)!
    January 2005
Posted by steves on Wednesday, November 28, 2007 6:56 PM
Another update on thin wire-there is a company called Ngeneering which sells .004" rigid staiinless steel wire in 9" lengths.  Available through the Walthers railroad catalog.
hwells-Thank you very much for the kind offer.  I now have rolls of .003" and .004"wire, both over 4,000 feet, so I probably won't need any more wire in this lifetime.
    November 2004
Posted by hwells on Wednesday, November 28, 2007 9:37 PM
Steve
Your welcome
Henry
