Any advice/recommendations for painting "wooden" ship decks?
    September 2004
Posted by toddramm on Sunday, December 9, 2007 8:20 PM
I am starting a new project: Tamiya's 1/350 scale Battleship Yamato.  In painting the deck, I want to simulate the real wood deck of the orginal.  I think I'm going to start by laying down a coat of Buff or Deck Tan.  But does anyone have any ideas on getting the molded "planks" on the model to vary in color?  I don't want the whole deck to be a single, unmarked color.  It just won't look right.  I thought about using lighter and darker shades of the base on some planks, to get that variation, put on by the smallest brush I could find.  But the molded "decking" on the model is very fine detail.  I'm doubting that a brush would even work.  In any event, any advice anyone could give would be greatly appreciated.  Thanks very much.
    March 2007
Posted by searat12 on Sunday, December 9, 2007 10:17 PM
I have found that applying a fairly light base color first, then a thinned down darker brown after, followed by a very thinned down black works pretty well.  Use a fairly large brush in all circumstances so that you can move the thinned down paint around quickly without letting it rest much until you have finished the whole deck, at which point the darker colors will migrate to the low spots (plank seams). To avoid problems with thinner 'lifting' the first color, use an enamel paint first (Humbrol, or similar), followed by acrylics.  Try a test on a cheapo model first until you get the hang of it........
    December 2006
Posted by Grahor on Monday, December 10, 2007 4:36 AM
There are many, many ways to emulate wooden decks. For planks to be different in color, here is a nice article on how to do it. The resulting decks are amazing, although work, put in there, is huge. :) Don't forget, that planks should vary in color very little, and don't overdo it!
I've accepted that technique once, and I, indeed, overdid color variations, even though I hadn't thought about it this way then. :) Deck will look like a patchwork of different types of wood, which it wasn't usually.
Other techniques can include, for example, drybrushing planks with different colors, using oils (my favorite) of different colors, but it's much harder than drybrushing... Experiment. :)
