Question on Aoshima 1/350 Takao turrets
    March 2007
Posted by searat12 on Wednesday, December 19, 2007 1:49 PM
I have had a close look at the various model photos available for this class by Aoshima, and one thing disturbs me, that I hope may be helped by some readers!  Looking at the model photos, it appears that the main gun turrets have some sort of peculiar raised ridges in a gridwork all over them.  Looking at photos and specs of the actual ships, I know that the turrets on these (and other) Japanese heavy cruisers actually had an additional layer of sheet steel on the outside to protect the actual turret and its occupants from the effects of the tropical sun (the effect is similar to 'spaced armor' for you armor buffs!).  While these 'extra' plates certainly had joins between them, they really are not too evident with the exception of the ventilation gap that follows the outline of the turret itself, and/or when the turret has not been painted for a long time with rust showing up the joins.  I would have thought this would have been a wonderful opportunity to do something with photo-etch plating to simulate this armor spacing.  Is there anyone out there with experience with this particular model (or Chokai) that can comment on this?  I'd hate to have to sand down this stuff!
    August 2006
Posted by honneamise on Thursday, December 20, 2007 1:09 AM
Yes Aoshima kinda screwed it up - the ventilation gaps are just a ridge and the plating is simulated with far too heavy raised lines. White Ensign comes to the rescue here - their upcoming Takao/Chokai photoetch set will include metal substitutes for all the turret sidewalls just as you proposed. I was dumb enough to order the Aoshima PE set for Chokai before checking the WE site, but I certainly have to have their set as well as it is MUCH more comprehensive!
    March 2007
Posted by searat12 on Thursday, December 20, 2007 9:47 AM
Hooray!  Thanks for the tip!   Sure would be nice if someone came up with some resin turret substitutes to go with photo-etch plating, but i will have a look at the WE stuff....
