Need some how-to help: coiling and seizing line
    May 2003
Posted by styrene on Wednesday, January 2, 2008 10:16 AM
I'm finally at the point of rigging a 1/80 Amati Rainbow (1934) that I've been working with off and on for about the last 4 years (more off than on).
2 areas I need help with:
1. A rigging line that I assume controls the raising and lowering of the mainsail exits the base of the mast on the starboard side, and ties off at a nearby cleat.  Since the sail will be raised, I am assuming extra line will be available that will have to be coiled on deck.
Is there an easy, straightforward way to coil line in one of those nice perfect circular spirals?
2.  The plans show that line going through eyebolts has to be seized (I said "served" earlier; my mistake).  I understand the concept (maybe?), but how, exactly, do you seize a line?  What's the best and easiest way to do it?
Please pardon the stupidity, but if you could explain it so a fourth-grader could follow along, it would be appreciated. (This is my first attempt at a rigged vessel.  I normally build armor....)
Thanks.
Gip Winecoff
Posted by lenroberto on Wednesday, January 2, 2008 10:27 AM
Hi Gip- I just recently learned how to coil ropes -  I'll try to explain-  found it in a book SHIP MODELING FROM STEM TO STERN
1.  get a block of styrofoam
2. put toothpicks in the foam-  about an inch or less apart
3.  tie line to one then coil it around as many times as you want.
4.  mix a batch of old Elmer's white glue and water-  50/50
5.  using an old brush-  coat the coil with the mixture-  let it sit about 3 minutes
6.  Then you can lift it off the toothpicks and place it where you need it.  More glue will fix it in place.
7.  You can also put the toothpicks at angles-  1 on edge and the other on the other side of the block-  this gives you coils at a 90 degree angle or so...
test it out and see if it works for you-  it made my day!
-Len
    May 2003
Posted by styrene on Wednesday, January 2, 2008 10:43 AM
Thanks, Len.  Sounds simple.  I'll give it a try.
Gip
Posted by kp80 on Wednesday, January 2, 2008 11:09 AM
I've been able to produce flat coils of line by taking a Post-It note and taping it upside down (ie, sticky side up) on a flat hard surface, then laying my thread out on the sticky part of the Post-It in whatever shape or pattern (circular, oblong).  The sticky surface holds the line in the desired shape and pattern.  Then use a mixture of white glue and water to coat it, and let dry.  Once it is dry, you can peel it off the Post_It in one piece and glue it onto your model.
Posted by results may vary on Wednesday, January 2, 2008 4:55 PM
I have had good luck coiling on masking tape.  Before I start coiling though I will de-stick the tape some by several applications to cloth or something, so that it's just tacky.  Then I just coil it up like described above and little glue and just like that... you have a coiled rope disk. Smile [:)]
paul "We are all made of star stuff." - Carl Sagan
    May 2003
Posted by styrene on Wednesday, January 2, 2008 6:23 PM
Paul and kp80:  Thanks for the tips.  Sounds really easy.   Now why didn't I think of that?Smile [:)]
Gip
