Any one brave enough for 1/72 gato interior build?
    January 2008
Posted by 96th BG 338th SQ on Wednesday, January 16, 2008 10:48 AM
  I am considering building a 1/72 gato with hyper-accurate interior, scratch built of course. Does anybody know of any other mentally ill individuals who have undertaken  such a project and, are any posted online?
  I am also interested in seeing some 1/72 type VII interior scratchbuilds. People mostly seem to be using the CMK compartments which are very good but, have some glaring inaccuracies such as, the omission of convex zentral bulkheads, lack of remaining compartments{including conning tower} and inaccurate main diving tank. Etc. I have seen Dick Janes u-boat in FSM{awsome} and, thats pretty much the level of detail i am seeking.
  This is truely the best modeling forum on the net and, you guys are the best of the best! THANKS!!!!!
Why does the cat glare at me?
Posted by Aurora-7 on Wednesday, January 16, 2008 11:51 AM
I was hoping by now one would be seen around the net. There has to be people out there with that goal.
Make sure you take lots of pictures of the process. Maybe consider submitting it as an article to FSM?
    November 2004
Posted by mkeatingss on Friday, January 18, 2008 12:24 PM
You are not alone!
I already turned a Lionfish into a Tench Class, Guppy IIA, with detailed interior. The big Gato is next. It'll be the same boat, different scale. First "as built", then Guppy with interior detail.
Mike K.
    January 2008
Posted by 96th BG 338th SQ on Friday, January 18, 2008 3:47 PM
  Hey Mike
  I've been an admirer of your work for awhile! Most notably your posts on rocketcopy's type VII and, gato site. I hope you post your future works and eagerly await them.
  Keep up the excellent work...............Regards, BillMake a Toast [#toast]
    February 2005
Posted by sgtmac on Friday, January 18, 2008 7:00 PM
On the SubCommittee website, under Photos-Sub Museums-Pearl Harbor Sub Museum Fleet Boat, I have posted pictures that I took of their 1/32nd scale USS BOWFIN on display. The model builder does not wish to be known. I have several other pics of this incredible model if you would like to see them. Maybe the aftermarket will step up and start offering some interior stuff like the U-Boat has now.
    January 2008
Posted by 96th BG 338th SQ on Saturday, January 19, 2008 9:33 AM
  Hey Mac
  Thanks for the info, thats really what i been searching around for. As far as CMK stepping up to the plate goes, they still haven't produced officer country, electric motor room, aft torpedo room or, conning tower compartments for the type VII. The war might over before they get around to the gato.Whistling [:-^]
  I'm a great appreciator of peoples scratch building and inventivness! You know who you are.....
   Thanks again Mac.     Regards, William
    November 2004
Posted by mkeatingss on Sunday, January 20, 2008 6:06 PM
I'm with you, William, I'm beginning to wonder if CMK will ever release those three compartments. I've been waiting a couple of years,now.
 And there are 9 compartments (including the conning tower) on the Gato. At least the Gato compartments have the advantage of being flat. Except for the forward and after ends of the hull, and conning tower (more pronounced, on the conning tower).
One nice thing about doing the interior, is, that errors will be, almost, undetectable. Things were constantly being more around. Even coming out of new construction, no two boats were identical.
And keep your local RR model shop in mind, for detailing parts. The head of an "N" scale bridgeport makes a perfect bow planes rigging & capstan motor, or a bow planes operating hydraulic motor, for a Lionfish. And an the bell end, from an "N" gauge diesel horn, glued to a small block of plastic, makes a perfect klaxon for each compartment. And why build planes control wheel when an "O" or "G" gauge, brake wheel, will do the job?
I'm an industrial grade "Lazy bastard". I never scratch-build anyhing that can be jury riigged from something else.
Mike K.
    January 2008
Posted by 96th BG 338th SQ on Sunday, January 20, 2008 6:36 PM
     Amen Mike,
   I've been scratch building the interior for the infinately retarded 1/125 u-47 cutaway, as exacting as i am able. Sort of as a dry run for the 1/72 atlantic boat though, it's slowly turning into a decent display piece of it's own. I have spent HOURS & HOURS making 1/125 hand wheels etc.( i'll try to post some pics-have to borrow digit. cam.) And i'm here to tell ya i'm all about raiding railroad supplies & and saving the strangest bits and pieces you have ever seen. Casting prototyped pieces out of resin rates way up there also..
   Its always great to hear your feedback Mike!!!!!
      God speed, William
    November 2004
Posted by mkeatingss on Thursday, January 24, 2008 2:51 PM
Ok, guys, enough talk. Let's plug in a few numbers.
First of all, I'm working from a Tench docking plan (I'm building a Tench class). I can't suggest, strongly enough, that you get the docking plan, for the class boat you're building. Better yet, the plan for that particular boat.
For particular interior details you'll need the ship's plans for the boat.
The pressure hull, not counting the torpedo rooms, is a tube 16' in diameter and 176' long. That's 2 2/3" by 29 1/3", in our size. I plan to use a 2 1/2" cardboard tube and shove 2 2/3" plastic disks (bulkheads) into it, to force it to size. Since were opening one side, anyhow, this should work.
Here's where you hit the first problem. The last 16' (2 2/3"), of the bottom of the pressure hull, tapers up 12 degrees (And, slightly, inward, at the sides). So that the aft end of the maneuvering room is a 14" (2 1/3") circle. The top is parallel, to the rest of the pressure hull.
The conning tower is 8' Dia. tube, with domed ends. It's straight for 13', the ends bulge out about >2'. The main radius of the end caps is (about) 7' with a 1' radius blending it to the main tube.
In the area of the torpedo rooms, the pressure hull is the outer hull. The forward torpedo/forward battery and after torpedo/maneuvering room bulkheads meet the outer hull and so, the outer hull becomes part of the pressure hull. You'll see what I'm talking about, when you look at the plans. Those bulkheads overlap the main pressure hull. The overlap is as little as 3" (at the top of the forward room) as much as 3' 6" (at the bottom of the forward torpedo room)
If you use a tube larger than 2 2/3", cut a slot out of it and pull it into the bulkheads.
Well? What are you sittin' there for? Head for your local hobby/rug/hardware store and start looking. Let me know when you're ready to look at the torpedo rooms.
Mike K.
    October 2005
Posted by sawdeanz on Thursday, January 24, 2008 8:27 PM
Hey, I also have the 1/125 revell u-boat cutaway. When I first saw it, I was like whoa! cool. Then I bought a book with plans and such, and I am like, whoa! this is not even trying to represent the interior of a u-boat. I've been putting it off, But I plan to eventually construct it as my first scratchbuilding experience. Obviously my expectations will be low, but I also thought about using railroad brake wheels for the valves. I'd like to see those photos, william.
    March 2007
Posted by bondoman on Friday, January 25, 2008 1:29 AM
A good friend of mine is on the board of the USS Pampanito Foundation. I know she's a Balao, but if it's useful to you guys I can easily walk over there from work and get photos of details etc. you might need. Just let me know.
I would seriously consider using plastic for the pressure hull. You are going to be gluing endless amounts of stuff to it, painting it etc.
    November 2004
Posted by mkeatingss on Friday, January 25, 2008 10:20 AM
There you go! Bondoman's got the secret, to building an accurate model. Ask a submariner. You don't know one? Don't bet on it. There are a lot of us out here. But there's an even easier way, go to this site:  http://ussvi.org/States.asp . Then click on your state. You'll find a list of USSVI bases in your state. Pick one, close to you, click on it and find out when and where they meet. Then just go to their meeting. Submariners like nothing better, than talking about their boats. You'll find W.W.II vets ("Pigboaters") and Nukes that are still serving.
And take a set of Ship's Plans. There's a surprisingly good chance you find some one who served on the boat you want to do. And, if not, you'll probably meet some one, who knows some one who served on her.
Failing that, come here, or Steelnavy, or the Subcommittee. All three sites are home to Submariners. Some diesel (Smoke) boaters, some nukes and some who served on both. There's no shortage of info, if you're willing to dig for it.
Now. As to why I like cardboard. It's easy to work and shape. But, after I've got it just the way I want it, I 'plastisize' it. I melt a little sprue in Tenax (or some other plastic soluble glue) And paint a couple of coats, on the tube. Once it's set up, I add more sprue to the glue (thicker mixture) and put on a couple of more coats. It takes some time, but I really like the results. All the advantages of cardboard and plastic.
Mike K.
    March 2007
Posted by bondoman on Friday, January 25, 2008 10:51 AM
Mike K.
Thanks for the tip.
    November 2004
Posted by mkeatingss on Friday, January 25, 2008 12:18 PM
You're more than welcome, but be caeful. You'll need the bulkheads in place, to hold the hull to shape. If you get the liquid plastic on them, they'll become a permanent part of the hull. Same thing if you're using and oversized tube, and using rubber bands to pull it into the bulkneads.
Paint the plastic on as close as reasonably possible to the bulkheads (and rubber bands), let it set, move them and finish painting. Repeat this till it's good and solid.
If you're using a really thin cardboard,it may soak all the way through. That means it'll take fewer coats, but it'll spread, stay farther away from the bulkheads (and rubber bands).
You'll probably start with a 36 inch tube, use the excess to test how much spread and penetration, you're going to get. Draw a pencil line all the way around, and paint up to the line. Then it's easy to measure the spread. Then cut the tube at the line, to check penetration.
You'll need 8 bulkheads. Seven 2 2/3 inches, in diameter, and one 2 1/3 inches(Maneuvering/After torpedo Room bulkhead).
The extra bulkhead is placed 2 2/3 inches forward of the Man/ATR bulkhead to locate the knuckle, where the pressure hull bottom turns upward.
I can send rough sketches and numbers to anyone who e mails me at <<mkeatingss(at)cox.net>>.
Mike K.
    February 2005
Posted by rokket on Sunday, January 27, 2008 6:21 PM
Hey 96th, Finescale did a feature on a fellow who scratchbuilt a gorgeous interior for the VIIC, and Alistair Wright added a LOT of great scratch detals to the CMK kits:
http://www.rokket.biz/models/modelsweb/rokket/u557/alwright.shtml
Mike of course has done the same (with those lovely torp rigging chains!):
http://www.rokket.biz/models/modelsweb/rokket/u557/mike.shtml
Mike, looks liek you're seriously thinking interior... crazy man!
AMP - Accurate Model Parts Fabric Flags, AM Uboat Goodies & More http://amp.rokket.biz/
    May 2007
Posted by RTimmer on Monday, January 28, 2008 8:38 AM
Thanks, Rokket for the link - totally awesome site! Fantastic information!
Cheers, Rick
    January 2008
Posted by 96th BG 338th SQ on Thursday, January 31, 2008 12:11 PM
   Aloha rokket Sign - Welcome [#welcome]
  Hey Rokket. I'm an big admirer of yours and, have been following your 1/72 Type VII build since the begining(awesome)!! I'm also a frequent visitor to your sites gallery, also excellent...Bow [bow]
   Like yourself, I like to open up hatches and expose sub-structure as much as possible. I'm building 1/125th Type VII w/ complete scratchbuilt interior as a means of planning my strategy for a 1/72 atlantic boat. I have developed some techniques along the way that may help other like minded builders of sub interiors. I've been using aluminum flashing as pressure hulls, deck plating, bulkheads as well as radio faces etc. Its thickness scales out pretty good, it cuts and drills easily, it can be embossed with a stylus to create rivets and other details and, scribes beautifully. You can coax it easily into curves and, even compound curves. It also responds quite well to super glue. I have also found that the concave bottom of large beer cans makes a pretty nifty convex watertight bulkhead as well as pressure hull fore & aft caps. Plastruct I-beams make great hull-ribs if you heat them up in warm sand (ala-hot plate) and then coax them into the proper radia.
  I'm sure your familiar with Revell's 1/125th Type VII u-boat and, its lack of hull detail. I was able to adapt your oil-canning technique to great effect and, was able to turn very thinly stretched sprue to create believable welds. A retired rapidiograph pen made quite a nice riveting stylus. I back-scraped & drilled to open up all limber holes and. even back-scraped the deck pieces to open up flooding spaces. It looks good but, becomes very fragile and, is very time consuming ( i'de have to think twice about doing that again)! Attaching all the visable bits of ribbing in the free-flooding areas is really fiddley but it is in any scale.
  This little project is in a state of many different sub-assemblies and, I'll have to borrow a friends digital camera if i'm to make any photo posts. ( soon to come)
  I have amassed a trove of type VII schematics and various other reference books and, that is precisely where i have to begin my Gato journey. I have little or nothing on fleet boats and, nothing resembling schematics. Any help in this direction would be greatly appreciated & welcomed. All the techniques i've invented and learned from you guys is gonna make this a killer build! I can't wait.
  P.S. I just finished reading wake of the Wahoo....A must read! Does hanshansa's great u-995 interior photo series still exist somewhere out in cyberspace? If so-do tell!   Regards, MacLeod  Dinner [dinner]
    January 2008
Posted by 96th BG 338th SQ on Thursday, January 31, 2008 12:46 PM
  Hey Mike K Pirate [oX)]
  Wow! You've invented composite materials for the scale modeler! Thats a really great idea, can't wait to experiment with it.
  I don't care what Rokket says, your not a crazy man. Interior scratchbuilding seperates the average everyday seaman from the IIw.o. youll earn your bunk in officer country!
  As always thanks for all your advice.
Regards, MacLeod
    January 2008
Posted by ModelX on Thursday, January 31, 2008 9:02 PM
now that would be an interesting build
Model eXcellence
    February 2005
Posted by rokket on Saturday, February 2, 2008 5:44 PM
96th - thanks for the kind words. re: Mike, he is DEFINITELY officer material, a storehouse of talent and knowledge.
I really like the beer can idea (and so much more fun to find stock than soda cans!) Impressive use of flashing and your stylus, love to hear about this tuff, great work. Get some pix up, love to see it.
Gato - Floating Drydock has en e-book of gato plans and pix, well worth the $25, and for pix alone,  Warship Pictorial #28 USN Gato Fleet Type Subs is beautiful.
Anxious to hear more.
Uhu
    May 2006
Posted by Uhu on Tuesday, February 5, 2008 9:18 AM
In 1946, the US Navy published a 200+ page manual for the Fleet Type submarine, very well illustrated with cutaway views and many illustrations of interior fittings and compartments.  I would say at least 90% of the documentation needed to build a credible cutaway model is contained in this book.  I was lucky to find an original, slightly damaged, on eBay for about $50, but an even better deal is this reprint:
 http://www.periscopefilm.com/book1.html
Even if you don't build the model, its very interesting reference material.
HTH
Dave
    February 2005
Posted by rokket on Wednesday, February 6, 2008 5:16 AM
Uhu,
Excellent info! Went to buy the book and a DVD, but having shopping cart troubles. Sure it will be sorted. Curse you for making me spend $$$!!! Banged Head [banghead]
    November 2004
Posted by mkeatingss on Wednesday, February 6, 2008 11:49 AM
Boy! This looks like one of those threads that just ain't gonna' die. Oh Well!!
First of all, thanks Rokket, but I don't deserve half the credit you give me. And I'm definitely not officer material. I'm just a nasty ol' rag-hat, lookin' to see what kind of trouble I can get into, or cause.
That Navpers 16160 "The Fleet Submarine" is, indeed, the finest source of technical info on the fleet boat available. But, and a big BUT, it's, basically, a Balao. Fairly close to Gato, a bit different from Tench. I'd strongly recommend Floating Drydock's drawings, and CD, for, at least, the class, And the boat, if available. After that check out Kurt Greiner's SeaPhotos for pictures of the boat you want to do. And, of course, Navsource.
For after market, check out "Iron Bottom Sound", "Nautilus Models" and "WEM" (Conning towers, weapons, decks, etc.) [still waiting on CMK for interiors] And, incase you don't know, Iron Bottom sound has limber hole pattern stencils for the Portsmouth boats. Nautilus has stencils for all three classes' (Gato/Balao/Tench) flood ports and valves.
And, if you find yourself with your back against the wall, on a particular piece of info, AND, you're afraid people will laugh at your rivet counting, if you ask here, drop me a line << mkeating at cox.net >>. I've either got it, know somebody who's got it, or know somebody who will know where to get it. Assuming it's out there. If it's not out there, somewhere, I may not be able to help. But it never hurts to ask.
Mike K.
Uhu
    May 2006
Posted by Uhu on Wednesday, February 6, 2008 5:52 PM
I also highly recommend the Floating Drydock plan book, in fact, all the plan books from this source are superb.  The author may not be prolific, but he is very thorough and exact.
Dave
Uhu
    May 2006
Posted by Uhu on Friday, February 8, 2008 10:17 AM
CMK has two additional U-boat compartments at the Nurnberg Toy Fair
    November 2004
Posted by mkeatingss on Saturday, February 9, 2008 9:03 AM
YeeeeeeeeeHaaaaaaaaa!!!!!!
Mike K.
    January 2008
Posted by 96th BG 338th SQ on Thursday, February 14, 2008 11:47 AM
 I know every ones very eager to cut apart a perfectly good and plenty expensive Gato kit and, then get neck deep in scratchbuilt sub machinery etc. Kinda like jumpin out of a perfectly good air plane. Right?
 Seriously though, its readily apparent that I'll have no shortage of expert advice or resources when i finally get this puppy underway. This has been a pretty cool thread thus-far! And are the rumors true? Could there actually be two more CMK compartments for the venerable 1/72 Type VII? Can I stand the pain?
 I'm sure Mike Keating is having a pretty good drool about now. I cant wait to see some more of his compartment work!!!!!
  Thanks to all, MacLeod Wink [;)]Yeah!! [yeah]
    February 2005
Posted by rokket on Sunday, February 17, 2008 1:55 AM
You hit the rivet on the head, Mac, we're all desperate to rip open a perfectly good 52" model... where are those cutters?
Keep us posted on yoru project! maybe we can offer help in the preplan stage, tho I think Mike has that well in hand.
    November 2004
Posted by mkeatingss on Sunday, February 17, 2008 10:52 AM
First up - cutting a hole in the hull half can wait till last. But,
probably won't. So there are a few things to keep in mind, before you start cutting.
One. The bow and stern inserts make excellent fore and aft boundaries for the opening.
Two. the upper (and lower) edge of the cut should be above (and below) the upper (and Lower ) edge in the main hull. (Necessary for good viewing)
Three. Mark off cut lines in pencil. Leave about 1/8 to 1/4 between the initial cut and pencil line. File the remaining plastic, leaving a small amount to do final sanding. And round the final edges To prevent chipping. If you want to be REAL nit-picking, bevel the inside edges to a thin edge to simulate the thin skin on the tank tops. Leave a thicker edge at the hard tank locations (Trim Tanks, Auxiliary Tank, etc.).
Four. Use plastic "T" or "I" beams to simulate tank frames (same location as hull frames). Pressure (interior) hull frames are visible both inside and outside the hull (Capped on both, "I" is best match, but harder). The same plastic, used for fore and aft compartment bulkheads, can be used for tank boundary bulkheads. In most cases, the tank boundaries will be on frames. Substitute a thin piece of plastic strip, in place of "I" or "T" beam. Once again, if real nit-picky, tank boundary bulkheads, with flow through holes at each frame. If you cut the bottom edge, far enough down, you'll be able to see the flood ports, the midship tank dividers and side bulkhead of the Negative tank. And don't forget the holes in all but Negative Tank side and Auxiliary tank divider.
Ahh. I can see from the look on your faces, you now understand where the "deer-in-the-headlights" look comes from.
Now, on to my question. Drooling? I'm Dying! Anybody got anything more on the CMK kits? Pictures? Notes? Release date(s)? Prices? ANYTHING!!! (Note "deer-in-headlights" look.)
Mike K.
    January 2008
Posted by 96th BG 338th SQ on Sunday, February 17, 2008 1:08 PM
   Howdy Rokket @ Mike Pirate [oX)]
  You inadvertently answered one of my pressing Q's. While visiting the official USS Wahoo page (my chosen subject matter) I came across some photos of wahoo in various stages of completion, I.E. tank frames being attached to the pressure hull sections and, wondered if there were interior P.H. ribs corresponding to the exterior frame locations. 2nd musing, are the ribs @ 2-0 ft. on center? I know that the u-boats "while being metric" scale out very nearly to 2-0 O.C. Interior pix of compartments gives little evidence of rib installations as they were largely sheathed and, covered in a thin layer of cork to inhibit condensation. In Forest J Sterling's (yeoman) book, wake of the wahoo, he describes how during depth charge attacks chunks of cork would rain down from the cieling.
  Interestingly, Destination Tokyo starring Gregory Peck was loosely based on Wahoos war patrols and LT. CMDR Mush Morton respectively.
  Mike, your hull prep techniques are of great help in getting around the planning stage of this project. Ya know, planning & research are as much of an enjoyment as building. Being that I want to build a port side cutaway of the Type VII & Gato, I think it'll be considerably easier to scratch build the high & low pressure manifold and, valves of the fleet boat as it has alot of levers as opposed to the u-boats exclusive use of various sized hand valves. The gato also has valves but are typically a much simpler type to fabricate. I built a Type VII high & low pressure manifold in 1/125th, the optomitrist says I should regain my eyesight in a month or two..Dead [xx(]
  A passing notion that I somtimes entertain is a 1/72 Gato group build. Someone could be responsible for prepping the hull and the installation of completed compartments. Other craftsmen could build one or two of the compartments etc. all under an agreed upon set of specifications and, one individual being delegated as forman (for lack of a better term) who could distribute templates and, oversee final assembly. What a cool online build site that could be. Has anyone else suffered with this type of temporary insanity?
  They've recently located the wreck of Wahoo off the coast of Japan and, There are dive pix floating around on the net. If you havn't visited the uss Wahoo site yet you may find it interesting. I've surfed around looking for CMK's allusive new compartments but, have found no pix yet. However I did find some great Yeti photos and Elvis's space baby pics.
  As always I appreciate your knowledge and expertise! Bow [bow] Bow [bow] Bow [bow]
 Regards, Macleod
