- Member since
March 2007
Posted by searat12
on Sunday, January 20, 2008 8:17 AM
There are tweo styles of planking, both equally acceptable. the 'curved' method, with a kingplank in the center of the bow for the planks to join is one method, and is particularly common in smaller-sized yachts (under 80'). The other method is straight planks, cut to size for fitting against the curving bulwarks and watercourse along the sides. In either case, the planks should NOT be varnished, but oiled, or left natural. A varnished deck is probably the most dangerous thing at sea on any boat, as there is NO traction whatsoever if it is at all wet! I almost broke my leg stepping between two boats, one of which had a varnished foredeck with just a light coating of dew..I was wearing deck shoes, but no matter, that leg went straight out from under me and I went down between the two boats! If that could happen in a harbor with just a bit of dew, can you imagine what it might be like to go forward at sea in the spray and rain? Might as well be on a skating rink!
