Resin Casting - RTV Molds
    January 2008
Posted by Big Wick on Sunday, February 10, 2008 5:54 PM
Has anyone used a RTV thinner to eliminate air bubbles in very small molds?
    August 2005
Posted by EdGrune on Sunday, February 10, 2008 7:03 PM
RTV Thinner?  Not aware of any such animal.   There isn't a product identified as such on the Smooth-On website  http://www.smooth-on.com/default.htm.  Smooth-On is one of the leading manufacturers of RTV & resin.
One of the recommended process is to vacuum the RTV after mixing/before pouring.  Then pour the rubber from a little extra height so that it forms a long string & entrains less air.   Pour into the lowest part of the mold and allow it to flow up & displace air as it rises.
I don't have a vacuum pump but I do have a compressor for the nail gun.   I have also had some success in putting the RTV under pressure (30 to 50 pounds) to squeeze down the bubbles to minimum size.
    January 2008
Posted by Big Wick on Sunday, February 10, 2008 7:09 PM
Ed
Micro-Mark shows a RTV thinner in their catalog.  It states that you can use up to 15% for making molds for thin castings.
    August 2005
Posted by EdGrune on Sunday, February 10, 2008 7:30 PM
What is the basic viscosity of the MicroMark rubber without the thinner?  What is the viscosity when thinned?
You will find that most Tin Cure and Platinum Cure silicone RTVs are 20K CPS and up.   For reference, water is 1 CPS.   Smooth-On's OOMOO products are ~4200 CPS and are excellent rubbers for the model maker.  They also look to be less expensive than the stuff at MicroMark.
    January 2008
Posted by Big Wick on Sunday, February 10, 2008 8:15 PM
Ed
I am new to this resin casting business.  I'll give it a try, nothing ventured, nothing gained!  Thanks for your help.
    January 2008
Posted by Big Wick on Sunday, February 10, 2008 8:35 PM
Ed
The lower the number (cps) the thinner? ...or is it the other way round?
    January 2007
Posted by dahut on Sunday, February 10, 2008 8:59 PM
Yeah guys thanks for this information
Cheers, David
    August 2005
Posted by EdGrune on Monday, February 11, 2008 9:16 AM
 Big Wick wrote:
Ed
Yes, the lower the number the less viscous (thinner).
Hey, a little science never hurt anybody .... http://www.vp-scientific.com/Viscosity_Tables.htm
Material
Viscosity in Centipoise
Water
1 cps
Milk
3 cps
SAE 10 Motor Oil
85-140 cps
SAE 20 Motor Oil
140-420 cps
SAE 30 Motor Oil
420-650 cps
SAE 40 Motor Oil
650-900 cps
Castrol Oil
1,000 cps
Karo Syrup
5,000 cps
Honey
10,000 cps
Chocolate
25,000 cps
Ketchup
50,000 cps
Mustard
70,000 cps
Sour Cream
100,000 cps
Peanut Butter
250,000 cps
    January 2003
Posted by cthulhu77 on Monday, February 11, 2008 12:39 PM
Yeah Ed, but what about breast implants?
http://www.ewaldbros.com
    January 2008
Posted by Big Wick on Monday, February 11, 2008 7:12 PM
Ed
Have you used modeling clay for molds?  I have both the non-drying and 'sculpty', any thoughts?
    August 2005
Posted by EdGrune on Monday, February 11, 2008 8:04 PM
 Big Wick wrote:
Ed
You need to be careful with clays.   Some modeling clays contain sulfur which will cause cure inhibition.    I don't think the plasticine never-hardening clays are too good.  Test & see what happens.   I made a master of some Sculpey, baked it, the used that as a part master with no problems.   I also have some Clean Clay product which is recommended as a molding material
    January 2003
Posted by cthulhu77 on Monday, February 11, 2008 8:25 PM
Spare yourself the agony and use modeling wax or solid resin. Clays change as they harden, so things like sculpy clay will go out of scale, and the modeling clays, as mentioned above, often have bad reactions to molding compounds.
    January 2008
Posted by Big Wick on Monday, February 11, 2008 8:37 PM
I tried resin casting into both clean clay and sculpty molds.  The resin didn't want to harden, and it left clay residue on the finished pieces.  I wasn't impressed.  Going back to my silicon molds!
    January 2008
Posted by Big Wick on Tuesday, February 12, 2008 6:04 AM
I don't always need to get hit in the head with a rock, but sometimes it helps!
I am building a 1/50 Gokstad Longship, and trying to make the rope thingie which acts like a deadeye on the front stay.  Every silicon mold I made (3) would leave small air pockets in the tight areas behind the cleat.  After our discussion here, I poured just enough material to cover the detail.  I then worked out the air bubbles with an Xacto #11 blade.  There were 2 bubbles which were literally jammed because of the small size.  After removing all of the bubbles from the detail itself, I then finished pouring the rest of the silicon letting material flow around and over the initial material.  The finished mold is perfect.  Once again, "Real old dog, new trick!"
Thank you all for helping me through this and I hope that this discussion will help some other resin casting 'newbie' like me.
