Anyone used Gators Masks?
    January 2003
Posted by emo07 on Saturday, March 1, 2008 10:12 PM
Hi,
Has anyone used Gators Masks to paint the camo on their warship models. I was thinking of ordering the paint mask for the measure 32 camo of the USS North Carolina in 1/350 scale. If so, what is your opinion and are you satisfied with the results.   Thanks,
emo07
" When I saw fighters escorting the bombers over Berlin, I knew the jig was up." - Herman Goering
    May 2005
Posted by Bgrigg on Saturday, March 1, 2008 11:11 PM
While I haven't personally used his masks, I've heard nothing but good things about them. I'm thinking about giving them a try myself. Kenny is a good man, and I expect he will stand behind his product.
So long folks!
    August 2005
Posted by EdGrune on Sunday, March 2, 2008 6:28 AM
I've just finished painting the hull of a Fletcher using Gators 3x/9d masks.   I sprayed the whole hull Haze Gray,  masked and pulled the Ocean Gray panels, painted then remasked & pulled the black panels, and painted.   It was my first attempt using the product.  I ran into two problems.
1) Getting the off the backing in one (hull) piece and getting it initially aligned and rubbed down.  There are some areas in the vinyl mask which were not completely cut through.  Aligning the bottom or top and bow.   Once they were aligned -- things generally lined up.  Perhaps clear masks would help.
2)  Misalignment on some panels which were sprayed the second color and reapplied.  I have some narrow gaps & holidays which I've had to mask & repaint individually.
I code marked the color for each panel before removing the mask from the backing.  That helped identifying which panel to pull.   On hindsight I would also draw an alignment tic across adjacent panels to help align the panels which are put back
I think it is a good product,  just need some experience on how to most effectively use the tool.  Again I'm going to go back to the concept of the learner kit.   Before investing in a big, expensive kit with all the bells & whistles, buy a smaller kit and experiment with a new product or technique.  It may pay in the long run.    I learned some stuff on the hull that I will use on the superstructure.
    January 2003
Posted by emo07 on Sunday, March 2, 2008 10:06 AM
Thanks,guys, for your input. I might just place that order.
emo07
