primers
primers
Posted by flyguy on Thursday, April 24, 2008 2:55 PM
This is my second attempt ,maybe the computer swallowed my first try or this will be the secon time it shows up .Anyway I'm inquiring about what is the best primer to use on resin kits after they've had their detergent and water scrubbing / Thanks in advance for any help.  Flyguy
Grit yer teeth an' grin !!!
    May 2003
Posted by qmiester on Sunday, April 27, 2008 12:44 PM
Primers, like paints themselves tend to be a personal thing.  Enamel, acrylics or laquers?  Automotive or model?  The few times I've used resin (I tend to do OOB), I went over the part after the wash stage and located any pinholes (a fact of life with some mfgs) and filled them with an automotive spot'n'fill putty.  When that's been cleaned up, I wash again and let the part dry.  I then apply several misted coats of primer allowing until I have a good covering w/o loosing the small details.  Hope this helps a little
Quincy
