The Aoshima is based on prototypes too.
Having built two within the last year and going just about GA-Ga over Lunar Modules, the Monogram kit is by far the best. It is accurate to the flight versions, the fit is excellent, and with the exception of the RCS nozzles, is just about perfect.
However, assembling the plastic is only the beginning. None of the plastic surface will be seen once the model is completed. Every square mm will need to be covered with foil, not just the lower stage.
Being a craft that only operated in space, the outer panels were a very thin sheets of aluminum. So thin, that household aluminum foil is at the correct scale. Plus it wrinkled. It wasn't smooth and flat.
You are in very good shape for research.
www.spaceinminiature.com/index.html Is a good start.
www.apolloarchive.com/apollo_gallery.html Has high res free download images from all the missions.
mek.kosmo.cz/newware/ Has a resin and PE set to die for for this kit. There are several US dealers that sell it too.
home.earthlink.net/~pfjeld/lmdata/ This site is a big help keeping track of the differences between each machine. None were alike in details.
Then scroll back a page or two and you can see both my attempts at a model of the LM.
If you really want to go nuts with it, check out Pete Mallagoodee's cutaway made from the Monogram kit.
I'll be happy to help you over any bumps, if you need it.
Enjoy it. Its different.
