Thanks for the prompt replys
All good ideas, I like the jig idea, that would be easy to build and suit lots of kits in the 1/144 scale.
I have already painted the white on my current project so I will try the narrow masking tape method for the second colour, aluminum.
I had not thought of the decal sheet idea, I have never used decals by the sheet. I have noticed in the past, when I use a white decal, that the underlying colour could be a problem, showing thru. I assume the right primer colour would take care of that issue.
The decal technique actually gave me an idea. If my masking does not create the kind of demarcation line I want, I could apply a narrow band of white decal to make a clean line.
Thanks again,
Doug
P.S. I have never used this forum before so I am not sure if my reply will be seen by all contributors or not, I am assuming so.
