So, here's my Columbia....
    December 2003
Posted by dhanners on Saturday, January 17, 2004 6:04 PM
I finished this last fall. Used the ancient Revell kit, which is helped quite a bit by aftermarket products....
http://hsfeatures.com/columbiadh_1.htm
I've toned down the forward RCS ports since the photos were taken so they don't look so "rusty."
Posted by gregers on Saturday, January 17, 2004 7:10 PM
WOW thats a great looking model. awesome work Dhanners.
Greg
Why torture yourself when life will do it for you?
Posted by Anonymous on Saturday, January 17, 2004 8:00 PM
Very nice. I saw the Enterpeise when I was stationed at Pete Feild in Colorado Springs, yours is just as cool.
    December 2012
Posted by FreedomEagle1953 on Saturday, January 17, 2004 9:49 PM
Hi ya dhanners ...
Very ... very ... nice ... you should be proud ... Bow [bow] ... and thanks for sharing !!! Big Smile [:D]
FreedomEagle1953
Chicago, IL area
"keep on building 'em ... but don't glue your fingers together"
    September 2003
Posted by mojodoctor on Sunday, January 18, 2004 7:05 AM
Outstanding build and a nice tribute!
Matt Fly fast, fly low, turn left!
Posted by Buddho on Sunday, January 18, 2004 9:57 AM
That is a Great job....Dhanners
The shuttle looks real....the weathering and brick detail puts it "over the top!"
Regards, Dan
Posted by djmodels1999 on Sunday, January 18, 2004 12:48 PM
Wow! Superb. Could you explain how you did the black insulation tiles? I'm not sure I understand what you wrote in that article..!?
Posted by Anonymous on Sunday, January 18, 2004 12:55 PM
Looks really great, dhanners. What does the base represent?
Posted by Anonymous on Sunday, January 18, 2004 3:09 PM
WOW!!!! absolutely beautiful Bow [bow] It even beats the ones on display at the Kennedy Space Center if I may say so. I hope to see that build up and how to in a future FSM issue!? Big Smile [:D]
    December 2003
Posted by dhanners on Sunday, January 18, 2004 3:30 PM
Thanks for the kind words. The HRSI tiles are from the Cutting Edge decal sheet, but I darkened them and tweaked them a bit; Columbia had extra HRSI sections on the tip of the tail after the SILTS pod was installed, and there are some black LRSI tiles on the wing glove. The Cutting Edge decals are great, but they need to be darkened somewhat, especially in 1/144th scale, in my opinion.
The base? Funny you should ask. The white thing with strange holes in it is just a spare piece of wood I use to cut things on and I use it as a backing when I drill holes in other things. That's why it looks ratty. The model's "permanent" base is a small picture frame with a mirror installed. A piece of brass tubing is attached to the frame, and it fits into a small hole in the belly of the Orbiter. That way, the viewer can see Columbia's underside. So far, my meager abilities with a digital camera have prevented me from getting a truly decent photo of the belly.
    May 2003
Posted by styrene on Thursday, January 22, 2004 8:53 AM
Cool kit and great build. I really like what you've done. Keep up the good work.
Gip Winecoff
    July 2003
Posted by 72cuda on Wednesday, February 4, 2004 11:32 PM
I've built that same kit years ago but the way you built it makes it look like something that came from Hasegawa or Tamiya's stable not from Revell's and it looks like you could board her, great job again, when I worked for Martin Marietta (before Lockheed merged) I was at the Cape working on Magellian and helped install it into the cargo bay and that really looks like it's one of NASA's inventory it even brought back memories of being so close to the bird, love to see her stacked out, or you should stack one out with all the flares used on this one
great job again and keep up the fantastic work
84 of 795 1/72 Aircraft Competed for Lackland's Airman Heritage Museum
Was a Hawg Jet Fixer, now I'm a FRED Fixer
 'Cuda
    July 2003
Posted by Dwight Ta-ala on Wednesday, February 4, 2004 11:35 PM
Impressive build. Great work all in all.
    January 2003
Posted by Keyworth on Thursday, February 5, 2004 5:52 AM
Great job! Thanks for sharing it with us.
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by mark956 on Thursday, February 5, 2004 11:33 AM
Darn it I could not see it. The website gateway is down. I will check it out later.
mark956
    June 2003
Posted by M1abramsRules on Thursday, February 5, 2004 1:43 PM
a fitting tribute to a wonderful machine!! great work, dhanners!!!!
Posted by mark956 on Thursday, February 5, 2004 1:50 PM
The link works for me now. Great looking space shuttle dhanners!!!
mark956
Posted by Anonymous on Thursday, February 12, 2004 12:06 PM
How did you darken the decal set?
I've got the same set that I want to use on my 1/72 stack (when I eventually get around to it!) but the tiles are too light for my tastes as is.
Posted by cassibill on Thursday, February 12, 2004 12:39 PM
she's really a beauty dhanners. What else have you done??
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by Anonymous on Thursday, February 12, 2004 2:00 PM
Ah, never mind. I must not have read your write up worth a darn the first time!
Posted by Anonymous on Thursday, February 12, 2004 5:34 PM
Excellent job!!!!!!!
Posted by Anonymous on Friday, February 13, 2004 9:20 AM
That is a very beautiful paint job, well done there!
Posted by Anonymous on Friday, February 27, 2004 12:40 AM
I'm blown away, that looks great.
you are an inspiration to the craft for sure.
Lon
Posted by Anonymous on Saturday, February 28, 2004 12:49 PM
very nice!! good job
Posted by Anonymous on Sunday, February 29, 2004 3:20 AM
WOW , very nice
    July 2003
Posted by oldhooker on Sunday, February 29, 2004 1:30 PM
Great job, David, it looks real!
Thanks for the pictures!
Frank
Posted by midnightprowler on Sunday, February 29, 2004 4:12 PM
Wow! Absolutely incredible! Blows away alot of 1/72 birds I've seen!
Lee
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
Posted by BlackWolf3945 on Monday, March 1, 2004 3:20 AM
A bit late here, but I have to say that that is one of the nicest shuttle builds I've seen in any scale. Groovy!
Fade to Black...
    July 2003
Posted by Kugai on Tuesday, March 2, 2004 3:21 PM
"impressive...most impressive." -Darth Vader
I might have to check that kit out. I gave up on the idea of building a shuttle because the kits I remember from years ago weren't worth bothering with. The last shuttle-like kit I attempted was the one from "Armageddon," and it was more of the same.
http://i712.photobucket.com/albums/ww122/randysmodels/No%20After%20Market%20Build%20Group/Group%20Badge/GBbadge2.jpghttp://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
    December 2003
Posted by dhanners on Wednesday, March 3, 2004 4:49 PM
Thanks again for the kind words. I'm surprised more folks haven't built shuttles, but then again, most of the kits that are out leave a lot to be desired. Now that there are a bunch of aftermarket parts and decals for the space shuttle, I would expect some great work to be done.
For what it's worth, I've only entered the Columbia in one contest, last fall's Nordicon in Minneapolis. It didn't place. The winners in its category were a Gundum, a V-2 and an "Icarus" from Planet of the Apes. I see why other "real space" modelers get discouraged when it comes to contests. It seems that more often than not, our stuff gets lumped in the "Space and Sci-Fi" category, as if something like the space shuttle actually belongs in the same category as a Gundam, or a piece of artillery (the V-2) or a vehicle from a sci-fi movie.
I don't build for contests, but I have a tough time with any outfit that thinks it makes sense to stick something like a space shuttle in the same category as those other things. The shuttle is a real vehicle with real references you can look up. You can look it up to see if the modeler has accurately represented the flexible insulation seals between the SSME gimbal mounts and the aft fuselage SSME fairings. You can look it up to see if the modeler has accurately represented the elevon hinge panels. So that belongs in the same category as a made-up Japanese robot suit? Or a spacecraft (and only part of a spaceship at that) from a sci-fi movie made in the 1960s? Or a WWII artillery shell that just happened to be propelled by a rocket motor instead of gunpowder?
It just didn't make sense to me and it kind of soured me on the whole deal. I've heard the argument that if there aren't enough "real space" entries then they have to be lumped in with the sci-fi stuff, but when you do that, you set up a pretty stupid competition. What would happen if the guys who built Me-109s woke up one morning and were told that their airplanes were going to be judged in the same category as Pontiac GTOs? Or if the guys who spend months researching the proper markings for a piece of German armor were told that their work was going to be judged in the same category as sailing ships? This is the very same deal. There is NO WAY in any rational competition and judging system that a space shuttle should be in the same category as a Gundam, and any judge who thinks there is is just daft.
Yes, I know it's largely about modeling skill and a badly puttied seam is a badly puttied seam, whether it's on a Panther tank or a Gundam or a P-51. But if that were truly the case, why have categories in the first place?
