Hello,
I'm not sure if this helps...I have a brochure I picked up at one of the space museums I have visited over the years, I'm afraid I don't recall which, either Houston or Cape Canaveral I suspect.
Anyway, the brochure depicts a series of paintings called " Pushing the Limits". As it happens, the artist, William S Phillips had done a painting in the series that shows the very scene you described here in your letter. The painting is called "The Right Stuff on Final" The tail number of the Talon ( I collect models of them ) to the right or starboard side of the shuttle is # 912.
I can't say if this is just coincidence, or if this artist knew " the right stuff" :) or that this painting represents a glide test or an actual landing..
At any rate..If you have a chance you could try checking out this website, it was printed on the above mentioned literature: http://www.nasa.gov/gallery/arts there are some pretty amazing paintings in that series if you are a real space, space buff!
Good Luck
Dave Rogers
