I've built one....
I've built one....
Posted by Anonymous on Friday, February 11, 2005 9:06 AM
The only thing I can say about the kit is to be very careful when aligning the Recovery Module parts. The RM is divided into 3 parts (sides) and if you don't cement them together in the proper position, it will throw off the alignment of the Service Module & the Orbital Module.
Be very careful when removing the thrusters from the trees, I lost one of mine (the one of the sixteen little bitty ones) & had to make do with some from a 1/144 AirFix Vostok with launcher kit. needless to say, I have extras if you loose any of yours.
I covered all three modules with aluminum foil to simulate the thermal blankets that were applied to the exterior of the real space craft. Judging by photos in Aviation Week & since the spacecraft is an enlarged knock off of the Russian Soyuz, I went with the foil. I painted the Service Module White, the Recovery Module a Metallic Graphite, & the Orbital Module Ghost Gray.
I took the stick on decals from the 1/48 Shenzhou Long March Booster kit and photo copied reduced the Chinese flag to a size that looked right and glued it to the Decent Module.
The solar panels where painted a dark blue black on the top with the supporting frame painted silver& the bottom panel painted Panzer Buff with the same silver supporting frame.
Over all, I did find fit problems with some parts & that is why I covered the model with foil. The seam clean up just looked bad over all. I was to lazy to try & fix the left over all imprefections. Besides, the real thing has thermal blankets on it so why not?
Hope this helps,
Steve Sliger
Posted by Anonymous on Friday, February 11, 2005 9:08 AM
I goofed, this should be under the Trumpeter Shenzhou thread
Steve Sliger
Posted by Anonymous on Saturday, February 12, 2005 3:45 AM
That's Ok, just click on reply at the bottom of the post you wish to reply to-which seems you have figured out to do. By the way Sign - Welcome [#welcome] to the forumsSmile [:)]
Posted by sb36 on Monday, February 14, 2005 7:13 PM
thanks for your input steve. the kit just arrived today, and its about what i expected. i'm rather surprised by the lack of intrest in this topic along with the soyuz tm's. i figured tamiya or another big name model company would have produced versions in 1/72 or 1/48. i've built the realspace versions in 1/72 much better detail but in resin. thanks again. Cool [8D]
