Does anyone know a replacement for Micro Sol
    March 2006
Posted by Yann Solo on Monday, March 13, 2006 1:49 PM
I'm currently building the atomic city mercury kit and I'm scared about installing the decals. There is so much uneven surfaces that I'm pretty sure I'll screw it up.  I looked for Micro Sol in my area but it seam to be hard to find here in Quebec (Canada).  I can have it online from Udisco but they want a minimum order of 10$.  I have nothing else to buy and I don't want to buy 5 bottles just to have that minimum you know!
If anyone knows a replacement solution for that Micro Sol product, I would appreciate the tip.
No matter where you go ....... there you are.
Posted by grandadjohn on Monday, March 13, 2006 6:04 PM
Testors makes two different decal setting solutions, might give them a try if they are available to you, use them myself because I used to have a hard time finding Micro Set and Sol in Phoenix in the days before PC's and mail order was not that great then either
Posted by Anonymous on Tuesday, March 14, 2006 10:25 AM
<BLOCKQUOTE><table class="quoteOuterTable"><tr><td class="txt4"><img src="/FSM/CS/Themes/default/images/icon-quote.gif">&nbsp;<strong>Yann Solo wrote:</strong></td></tr><tr><td class="quoteTable"><table width="100%"><tr><td width="100%" valign="top" class="txt4"><P>I'm currently building the atomic city mercury kit and I'm scared about installing the decals. There is so much uneven surfaces that I'm pretty sure I'll screw it up.  I looked for Micro Sol in my area but it seam to be hard to find here in Quebec (Canada).  I can have it online from Udisco but they want a minimum order of 10$.  I have nothing else to buy and I don't want to buy 5 bottles just to have that minimum you know!</P>
<P>If anyone knows a replacement solution for that Micro Sol product, I would appreciate the tip.</P>
<P> </P></td></tr></table></td></tr></table></BLOCKQUOTE>
I'm told that a mixture of 50% acetic acid (white vinegar?) and 50% distilled water will make a good substitute for MicroSet (the weaker of the two MicroScale setting solutions). Scott Alexander, whose Atomic City company released the kit and whose decals I designed, recommends that you brush on a puddle of setting solution over the area of shingles where you're placing a decal like UNITED STATES, slide the decal onto the puddle and position it as best you can with a brush or cotton swab, and then gently blow the decal down into the corrugations. He says the decal will soften and begin to snuggle down.
I use the Microscale solutions basically because the quality is pretty consistent, but you're certainly free to mix up your own.
Rick
www.spacemodelsystems.com
    March 2006
Posted by Yann Solo on Tuesday, March 14, 2006 11:22 AM
Thanks a lot for the tip Rick, I'm a little more confident now.
By the way, your decals look awesome!
    January 2003
Posted by leemitcheltree on Tuesday, March 21, 2006 5:29 AM
Yann,
I also use a decal softener made by Gunze Sangyo........it's called Mr. Mark Softer.  It works quite well - I use both Micro Sol and Mr. Mark Softer.
Cheers, LeeTree
Remember, Safety Fast!!!
