Pics of Saturn V with almost final coat of white.
Posted by Anonymous on Wednesday, August 20, 2003 1:56 PM
This model is not for showing off excellent assembly techniques. I decided to use it instead to relearn airbrushing.
I finally found that a 1:1 enamel to thinner (both testers) at 20psi using a Badger Anthem Airbrush works very well with flat white for preventing that grainy rough texture. In fact a .75:1 thinner to enamel would be better as the 1:1 takes several coats to cover and will run at the drop of a hat.
These pics are showing both the good and the bad. What can be seen around raised detail are the remnants of various attempts that were all failures.
http://www.cronusengineering.com/cronuswarp/SNITZ_FORUM/photo_album_cat.asp?sqldtl=1
Posted by Anonymous on Wednesday, August 20, 2003 4:36 PM
Another great lesson learned. Thanks for the info and pics!
demono69
Posted by Anonymous on Wednesday, August 20, 2003 4:54 PM
Yep, lot's of lesson's learned here. The biggest one is that your skills while there go dorment if not used frequently.
Your welcome.
    January 2003
Posted by Keyworth on Friday, August 22, 2003 11:53 PM
Looking pretty good! Post your progress while the build's ongoing! :)
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by Anonymous on Saturday, August 23, 2003 10:32 PM
NOot a problem. I am going to mask off fo the black on Sunday and hopefully get the black painted as well.
